Results 1 to 4 of 4
    May 2011
    Ireland
    Default Ford transit 2006 no millage on the dash.
    Hi all
    I have transit 2.4 2006 with tachograph.
    There is no millage display on the dashboard or tacho too.
    I have change battery on the tacho but still no successful.
    Also speedo is not working.
    How to fix it any idea?
    super jumbe's Avatar
    Dec 2008
    Livingstone
    Drive for 2 miles see what happens.
    May 2011
    Ireland
    Nothing just completed test drive
    smartymarti's Avatar
    Jan 2011
    cornwall
    factory fitted tacho , put a second hand one in all will work , if you remove tacho and have ----- along dash then your stuffed at there wired into the main loom , and havnt seen any solution of removing tacho and correcting dash
    All about the Bass
  5. The Following User Says Thank You to smartymarti For This Useful Post:
    czaderx (17th November, 2015)
