for good egr off need full bdm
Hello mates,
I've bought a used 2008 astra H 1.9 cdti 150hp. (Manual)
The only mod it had been done from the previous owner, was the removed DPF. (physically and from the ECU)
The previous owner told me that also EGR was disabled from the ECU, but seems it didn't.
Now, I've made these modifications:
-Full 76mm decat exhaust
-EGR blanked
-Swirl ports removed
-Cold air induction
-Custom bigger front mount intercooler
After the EGR blanking, I have constantly the "P0400-5A" error.
Could someone remove the P0400-5A error and give the best efficiency for this modifications that have been done?
2008astraz19dth.zip
The file has been read with KESS v2.
Thank you in advance,
Thanasis
Agwnistikotatos (17th November, 2015)
Remove EGR connector
Good morning!
Which is the limit pressure for the stock turbo?
I was thinking to set the requested pressure to exceed the map sensor readings eg 2bar and control the pressure only through the requested duty cycle throughout the rpm. Eg. 80% @ 3000, 90% @ 4000, 100% @ 5000.
Is it possible?
For what horsepower are capable the stock injectors and which is the maximum fuel rail pressure can be achieved with the stock high pressure pump?
Thank you!!!
Any ideas, guys?
P0400-5A just came on again...
:/image.jpg
Because EGR off solution is bad, needed make BDM dump and then can get correctly off....
All brand FileService - Custom - remapping company
POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
| Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
Agwnistikotatos (18th November, 2015)
I have found my full BDM readout ori, on the internet....
https://www.carfiles.net/opel-astra-...-edc16c39-1350
Could this help?
It could, but you will need to bdm it to the ecu, not obd.
Yes, obd is partial, no matter you try to read or write.
I understand.
Thank you.
