Remove EGR that's solution for problem. Only one DTC not resolve
I have fault code P4501 from a bmw 118d 143hp.
Fault code is from the egr, but i can't see any wrong on my car.
Car goes very good. Only the EML light goes on, i delete DTC by autocom, after 200km the light goes on.
Can i delete the dtc fault code in the file ?
Ecu is edc17cp02
Is this good idea to delete the dtc in the file ?
Greetz
All brand FileService - Custom - remapping company
POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
| Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
You mean remove EGR manualy ?
I can't do it without egr off,
When i egr off, (manual and software) problem solved ?
hi my friend: you must first remove and thoroughly clean egr then you r?nitialise with the autocom if the egr changes and make the adaptation always with scannair
