    spiridonas's Avatar
    Default Kess v2 can't read opel astra h z14xep ecu me7.6.2
    Hi guys i tried to read via obd the opel asta z14xep ecu with kess v2 but can't read the flash only info from ecu.
    Please how can fix this error ?
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    Friend ...Kess2 ori read ...no clone!! carProg Ori ... Read ...no clone!!
    ..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
    Aug 2011
    germany
    use FG tech V54 will go as Pro
    Quote Originally Posted by spiridonas View Post
    Have you tried reading with over 13v to the car. Put jump leads from running vehicle
    spiridonas's Avatar
    Hi i tried to read in bench with 14,7v with kess v2 and fgtech v54 but the same result.
    With fgtech when click read file (flash) go the green bar quickly (1'') 80% and after says error.
    With carprog clone i read succes the flash but has not write button.
    Please why can't read with clone kess v2 and fgtech v54 this ecu ?
    nick_f's Avatar
    GR
    spiridona with kess v2 i read yesterday me7.6.3 without problem.
