Results 1 to 7 of 7
    Jun 2012
    Default Smart 800 CDI Edc15cg egr off
    Hi to all. I have a problem with a Smart 800 cdi Edc15cg. The car has problem at EGR, dtc P1403. I have tried to switch off the EGR on file, but same problem. With switch off file and EGR disconnected, the car go to max 30 km/h.
    Someone can help me with a solution to disconnect EGR connector?
    Attached ori and switch off file. Thanks.
    mihaiservice's Avatar
    Dec 2009
    http://www.quick-tuning.com
    here you have egr off and dtc off related to egr !
    Full WinOLS user
    Custom ENG/GER OLS file for ​ Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
  3. The Following 4 Users Say Thank You to mihaiservice For This Useful Post:
    bobolin4o (28th December, 2015), cawadany (21st November, 2015), Min2xx (28th December, 2015), notoetannoto (24th March, 2016)
    Jun 2012
    Quote Originally Posted by mihaiservice View Post
    Writed. Seems to be ok. Egr disconnected, no dtc, and no limp mode. Thanks!
    Sep 2009
    Lithuania
    Hello,
    Same ECU, need the same solution .... EGR and DTS off, or password
  6. #5
    Nov 2012
    Quote Originally Posted by Min2xx View Post
    Hello,
    Try this
    Smart_EGR_OFF.rar
  7. The Following 2 Users Say Thank You to chiptuner8 For This Useful Post:
  8. #6
    Jan 2016
    48683 Ahaus Germany
    Hi guys, can you explain what this sullotion does, because my smart cdi from 2001 keeps having problem with the EGR keeps cloaked in a short time. For a while it's get stucked in the closed possition but of course the software keeps telling me that this happens at the fault code. By stucked in close position the car runs fine but when i can eliminated the egr that would be great.
    Thanks in advance, Rene
  9. #7
    Aug 2015
    Cassino
    smart 161-855.zip
