Hello everybody
I need some help please
I worked on Seat ibiza 1.6 tdi 90cv PCR 2.1 03L 906 023 LC CAYB motor
Ecu patched with trasdata. But after unlock the car don't start. No answer to diagnostic vcds.
Tryed to put it back to ori file but same problem.
I checked every fuse on the car, Tryed to clean the pin, checked ecu pcb to see if there was a problem a the opening but nothing.
I am able to read and patch it again with trasdata but same problem.
If there a solution to check if Ecu is dead ?
AND is there a solution to duplicate/clone PCR 2.1 with a used one ?
I'm blocked with the customers cars.. any help will be welcome
Thanks to all
