Help med17.5.2 boot - bricked ecu
Results 1 to 15 of 17
    34
    Downloads
    5
    Uploads
    Default Help med17.5.2 boot - bricked ecu
    Hi, today read jetta med17.5.2 with boot kess, made file and start writing... When it came at 99% gives error comunication not present and cant resume at all (tried about 20 times)... I tried writing again but kess cant recognize ECU, made a backup (with corrupted file i tried to write and fail) and notice it is smaller than it should be
    It has 27bits less than a normal backup.
    Tried to write backup but it cant recognize as med17/5.2 and when i try to write backup it says edc17cp46 and can write the wrong smaller file, but when i try to write a file with correct size it says file is damaged.
    Fgtech v53 cant read passou
    Ktag cant load pluggin to read or write it
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    174
    Downloads
    6
    Uploads
    I think i will be able to help pls post readed file here.
    you write as separate or full ? with full via KTag i will not help.
    All brand FileService - Custom - remapping company
    POWER>DPF>EGR>KL>TVA>DTC's>Lambda>NOx>CustomSpecia lization - | Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
    AutoTuner Tool authorized dealer
    Oct 2015
    6
    Downloads
    Uploads
    Never read an write edc/med17 via OBd!
    34
    Downloads
    5
    Uploads
    I wrote only flash, you want backup readed after it bricked?
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    174
    Downloads
    6
    Uploads
    Yes post it, should be helped bring it to liFe.
    Dec 2010
    13
    Downloads
    4
    Uploads
    Quote Originally Posted by OVERSPEED View Post
    MED17.5.2 has no Flash! Only processor.
    34
    Downloads
    5
    Uploads
    Quote Originally Posted by filecloud View Post
    You know what I mean, these ECU has no external memory, even eeprom (imobilizer, vin,etc) internal in processor too.
    FLASH = calibration maps
    EEPROM = individual settings, VIN, imobilizer, etc
    15
    Downloads
    3
    Uploads
    IROM and EEPROM
    Pro VAG Petrol Tuning | Pro DPF Removal | MED17 TPRot Removal
    Downloads
    Uploads
    fix your problem whit odis engignering.
    Dec 2010
    13
    Downloads
    4
    Uploads
    Ok. Please send the original readout you did. The file must cover the complete processor including otp area to achieve something.
    34
    Downloads
    5
    Uploads
    Here is "FLASH" (IRON) original readed by Kess
    Dec 2010
    13
    Downloads
    4
    Uploads
    Good.
    Go find someone next to you with an original Byteshooter v4.0 or a EVC BSL with ADP. Then i will calculate your boot password and you can fix the ecu.
  13. #13
    Top Poster VRPerformance's Avatar
    Bulgaria
    7
    Downloads
    Uploads
    1 QUESTION - is your tools original?
    ECU Tuning, DPF and FAP remove,EGR remove, Flap remove,DTC remove,Dyno tested files!!!
  14. #14
    34
    Downloads
    5
    Uploads
    Every guy I know around here use Kess, Ktag or Fgtech... I guess only one has byteshooter.
    When I try to read password with FGV53 it shows
    06J906027A..
    .......5E.......
    BPG-81002.01.12P3H07
    02.01.12
    13240163
    And says "for this news ECU we have no password at moment"
    Can someone point me is there is some way to recover it with Kess or FGtech ? There some way to discover the password from file readed in backup by kess ? (by the way what is this format readed in backup with kess ?)
  15. #15
    34
    Downloads
    5
    Uploads
    Don?t know if can be of one help, but when I try to write/read (even without the password)
    it shows:
    CPU ID 0000900001820
    int flash ID 0053C001
