Mercedes Atego 2012 Electrical Wiring Diagram Needed
Results 1 to 4 of 4
    Apr 2011
    Default Mercedes Atego 2012 Electrical Wiring Diagram Needed
    Hi. I need electrical wiring diagram/schemes for 2012 Mercedes Atego 916. I need for instrument cluster, tachograph...
    Problems:
    - speedometer in instrument not work
    - digital speedometer on display not shows/not working
    - tachograph no work (no light .. nothing)
    I've scan with diagnostic tool and here are fault codes:
    - 1520: CAN bus to tachograph has failed // no signal from the module V FR/Drive Control IC // CAN line failure or interruption between tachograph and instrumentation
    - 4345: Speed signal has a break or short circuit to ground or short to contr positive.
    - 0162: Can "Signal V" message from tachograph is wrong
    - 3620: The electromagnetic valve MKUE1 has an interruption.
    Apr 2011
    Can anyone share wiring diagrams ?
    Oct 2010
    I have the exact same problem , dash is gone totally dead , this in my opinion is a problem with the dashboard itself , as there are many company's out there repairing this type of dashboard , can anybody out thee share any information with the repair procedure for this type o dashboard ?
    Oct 2018
    Hi im reed this and i have wiring diagram from atrego and atron, is more recently but mby help... dont forget the thanks! https://mega.nz/#!xk0TiSQQ!fQCtRauYH...TJYZZ99A5Wd3Jg
  5. The Following 9 Users Say Thank You to Estebanpuri For This Useful Post:
    bidu20 (14th March, 2022), eeprom241 (3rd June, 2022), jnegretti (10th August, 2021), Makiszabi (10th January, 2024), nabilahmed (29th January, 2022), NICOBALO (25th February, 2020), skens (13th November, 2023), vydmasavas (5th July, 2020), yassine03 (13th August, 2019)
