I can make it for you. 1hour waiting. I will post when done.
All brand FileService - Custom - remapping company
POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
| Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
CHK not calculated. As said I tried some soution for DPF and EGR off but not work. I don't find switch.
as file cloud said it has been approached badly.
do you have the original file so the dpf and egr can be done again for you
PRESS THANKS + REP IF MY POST HAS HELPED YOU
DPF, EGR , ADBLUE, SPEEDLIMIT, LAMBDA, IMMO
were original file, you file allready mod. egr not off 100%,dpf 50\50
Sorry!
Here is file without modified DPF EGR parameters. Need to switch off EGR too if possible
Thanks!!!
File is not original! File still bad modified and checksum wrong.
Better find a full original file first
chk not calculated after tuning made thats why is not ok. only some maps modified DW TL, smoke, turbo. nothing about DPF and EGR. At moment I can't access to my complete original wihtout tuning.
EDIT:
Got ori file on my flash drive.
complete ori uploaded
Fec001 (30th November, 2015)
at 99% solution connection should have connection.
