Peugeot Partner/Citroen Berlingo 1.6 HDI - EDC17C10
Results 1 to 4 of 4
    Feb 2015
    3
    Downloads
    Uploads
    Default Peugeot Partner/Citroen Berlingo 1.6 HDI - EDC17C10
    We do many of above vans for DPF remove and DTCS all work fine afterwards as NO faults and NO LIMP
    only problem we are having is some leave triangle symbol on dash and either 1 of 2 messages display on centre lcd screen,
    Risk of Filter Clogging
    or
    Engine Fault Repair Needed
    We have DIAGBOX Citroen/peugeot so can any body recommend a way round this or where to go to get this display off
    Someone mentioned changing country of origin on vehicle is possible and then wont even need a dpf off file also but we tried turkey but made no difference if someone can recommend what country to try this would also be a help.
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    174
    Downloads
    6
    Uploads
    So your solution for DPF off is wrong or not complete, car see soot in eep, and using relating reading information form ECU show you error on dash.
    All brand FileService - Custom - remapping company
    POWER>DPF>EGR>KL>TVA>DTC's>Lambda>NOx>CustomSpecia lization - | Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
    AutoTuner Tool authorized dealer
  3. The Following User Says Thank You to CustomCars For This Useful Post:
    ecutuners (25th November, 2015)
    pawelelectro's Avatar
    Jun 2011
    146
    Downloads
    120
    Uploads
    I have simmilar problem. How to resolve this ? My DPF OFF file is 100%ok. Soot mass 0g. No dtcs but "Risk of Filter Clogging" message. Any idea ?
    Jun 2011
    146
    Downloads
    120
    Uploads
    Just resetted eolys level in additive ecu and works excelent
