So your solution for DPF off is wrong or not complete, car see soot in eep, and using relating reading information form ECU show you error on dash.
We do many of above vans for DPF remove and DTCS all work fine afterwards as NO faults and NO LIMP
only problem we are having is some leave triangle symbol on dash and either 1 of 2 messages display on centre lcd screen,
Risk of Filter Clogging
or
Engine Fault Repair Needed
We have DIAGBOX Citroen/peugeot so can any body recommend a way round this or where to go to get this display off
Someone mentioned changing country of origin on vehicle is possible and then wont even need a dpf off file also but we tried turkey but made no difference if someone can recommend what country to try this would also be a help.
All brand FileService - Custom - remapping company
POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
| Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
ecutuners (25th November, 2015)
I have simmilar problem. How to resolve this ? My DPF OFF file is 100%ok. Soot mass 0g. No dtcs but "Risk of Filter Clogging" message. Any idea ?
Just resetted eolys level in additive ecu and works excelent
