Page 1 of 19 12345611 ... LastLast
Results 1 to 15 of 282
    jattal786's Avatar
    Nov 2012
    KSA
    Default Need Hyundai ACU Code for Airbag Module Programing
    i need hyundai vin to Acu code for airbag module programing please help me thanks
    VIN : KMHFG41HBEA275233
  2. The Following User Says Thank You to jattal786 For This Useful Post:
    taxo1965 (19th May, 2022)
  3. #2
    Jun 2010
    far far away
    hi did u find out ?
    If i helpful don't forget to give thank
    Oct 2015
    Hi i need hyundai vin to Acu code for airbag module programing please help me thanks
    vin: KMHJT81C4AU035875
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Quote Originally Posted by jattal786 View Post
    Your pin : 215248
    You use srs units files at your own risk. I am not responsible for any damages. Don't ask about passes, one file=one pass.
    If I helped, please, use magic buttons reputation+thanks.
    Best regards.
    Dragon
  6. The Following 2 Users Say Thank You to dragon100 For This Useful Post:
    alclot (12th December, 2018), jattal786 (Yesterday)
  7. #5
    dragon100's Avatar
    Jan 2012
    Quote Originally Posted by payamhtc View Post
    Try pin 105680.
    Best regards.
    Dragon
  8. The Following 2 Users Say Thank You to dragon100 For This Useful Post:
    RylAuto (30th August, 2020), taxo1965 (21st August, 2019)
  9. #6
    Dec 2014
    LOCATING
    Hai...
    I need ACU code of this VIN : KMHCT41D1GU047629
    Please help me..
    Thanks..
  10. #7
    Aug 2016
    none
    connect yuor old module and them connect the scanner to your auto
    you can get it and go srs ecu information thas what i did my self
    you can try with another auto same year connect the scanner is only two acu code for each module
  11. The Following User Says Thank You to angel garcia For This Useful Post:
    sanjeev (4th April, 2017)
  12. #8
    Dec 2014
    LOCATING
    Quote Originally Posted by angel garcia View Post
    Actually the original module damaged accedently. The new module from other same vehicle. with your kind knowledge, any chance to swap and coding..?
  13. #9
    Dec 2014
    LOCATING
    How can i errase the old coding.? how can i re write the coding if it is already coded.
  14. #10
    Dec 2014
    LOCATING
    Help... ..?
  15. #11
    Jul 2014
    Brasil
    hello friend, you need virgin file... i think not possible erase ACU.
  16. #12
    Aug 2016
    none
    what years part nunber i have virgen file brand neew from dealer
    i need the part nunber ok
    i chek if i have
  17. #13
    Aug 2016
    none
    i did my self i swap the code .in the file show the 4 acu code leters and nunber
    you need the know the old want
    las time i have the same problem what i did i get from another car
    same year same module is only code to aling the abs with the srs modle
    i fis my 2017 elantra i chek another car whas the same acu code
    i have autel scanner you can chek what code use the module
  18. #14
    Jun 2012
    ACU code of this VIN : KMHCT41D1GU047629 is RB14
  19. The Following User Says Thank You to aparni198 For This Useful Post:
  20. #15
    Apr 2017
    Quote Originally Posted by aparni198 View Post
    Hello, someone can provide me a ACU code for this vin: KMHSU81XDEU223503
    thanks a lot!
