Results 1 to 3 of 3
Thread: help dm500c
    Default help dm500c
    hi, my problem is put the new fix in my new dm500c i did flash with dk 1.1, when i use flashxp to put the fix no connetion with the dmbox i use 5e patch cable, i did everything in the faq still the same problem any help please ciao salvo
    May 2009
    you connecting straight from PC to dreambox? a normal patch lead won't work, you need a cross over patch lead.
    Mar 2008
    if your dreambox worked first time, its very rare the network port would stop. So also possible settings in your software if messed up?
    Setup: 2x Dreambox 800HD | 3x Dm500S on Motorised dish Setup
