Results 1 to 3 of 3
    rex89's Avatar
    Not Near Tricore MCU
    Default cas3 need synch isn with tricore eep
    Hello guys , please i need help for this car E87 diesel old ecu is dead i get other used with same numbers
    i just need to synch cas3 with ecu i read eep from tc1766 tricore.
    thanks for all
    Best Regards
    Imagination is more important than knowledge, because knowledge is limited ... while imagination creates the world.
    Germany
    You can try this. This car has 16Byte ISN. I put the isn from ecu into your cas dump. But if your cas is cas3+ i think it wont work, because then you isn in cas is crypted. There are tools, which can decrypt and crypt this isn with some known info?s from keys. But I dont have this tool. Maybe you can set isn with diagnostic like avdi can. Your 16 Byte ISN from ecu is:
    DEF538C16781143388C3FC9EA99B32BD
    Good luck.
    Greetings MR...
  3. The Following User Says Thank You to brobble For This Useful Post:
    csavargo2 (11th January, 2016)
    Germany
    VIN in CAS is from E90 2007 3er BMW... Are you sure, what you are doing? :-)
    Greetings MR...
