Results 1 to 3 of 3
    Oct 2015
    Default Bosch 40048 injector driver
    I have a bosch ECU and my car have problem with engine. When I test with diagnostic tools all time is present this error : INJECTOR 4 DRIVE SHORT CIRCUIT. I have all wire and they are OK. I think the problem is the chip that I have attached below. But if I change this chip with another new chip with same number can I solve the problem. This chip have need to be programmed ?
    Andrei2015's Avatar
    Oct 2015
    What ecu/car/engine you have?
    Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
    VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
    POPS & BANGS (Schubabschaltung, Crackles)
    Oct 2015
    Fiat 500 L 1.4 liter petrol. It's ME17.9.X bosch
