This is what you need to read/write to the 8805 IC. It is difficult without these programmers and the software. Picture 054.jpg
very great,friend,this most chip have bad,i changed new ic is no work,
can you help me?friend.what you tool do?
Do you have in board TMS320
Hi I think that the firmware in Am29LV160D
I would first tested verify sdram 48lc2m32b2
new xs8805b0bq put is working?
Firmware is in BGA flash.
XS8805B0BQ doesn't contain internal memory.
There is onboard programmable flash and ram memory in this chip. Here is the promotional data sheet
http://www.digchip.com/datasheets/pa...339/OS8805.php
thank gapco,i have change new this chip,is no work,have look pdf ,have 128kb flash memory and 4kb data ram!
Put back the original chip because that is programmed. The new chip is empty and you do not have the tools for programming. The fault maybe is the corrupted flash chip AM29LV160. To read/write to this flash you still need the programming tools. I repair between 8 to 10 amplifiers like this every month. I have NEVER replaced the OS8805 chip.
Good luck.
My bad,I wanted to say that all relevant data for his error is stored in AM29LV160.
have good working cjip xs8805 buy?
