Page 1 of 6 123456 LastLast
Results 1 to 15 of 76
Thread: Corsa D BCM
    filutek's Avatar
    Silesia
    Default Corsa D BCM
    Walkthrough how to read the BCM:
    EEPROM CHIP 28000766 = 93C86 and NEC 70F3379 or 70F3632
    I have read the files without a known code, and need the files to a known code because I was looking for a solution on code.
  2. The Following 12 Users Say Thank You to filutek For This Useful Post:
    budata (7th December, 2021), BusCan (2nd June, 2021), byyoyo (17th October, 2019), conan981 (14th February, 2020), DOUGLASDL (5th December, 2015), ecufix (15th April, 2016), Hayssam1 (23rd May, 2020), motor25 (26th December, 2020), racin-snake (12th February, 2017), rbunn (15th February, 2017), xseva (5th December, 2022), yellowstilo (30th August, 2018)
  3. #2
    Jul 2012
    Quote Originally Posted by filutek View Post
    friend with which programaor made this reading?
    filutek's Avatar
    Silesia
    This: http://www.lzqcdz.com/Home/Goods?id=2194688&From=0
  5. The Following 2 Users Say Thank You to filutek For This Useful Post:
    DOUGLASDL (5th December, 2015), willyboy28 (19th August, 2019)
  6. #4
    UK East
    Post the file first so we can check its a good one.. Then maybe one of us can post you back another
  7. The Following User Says Thank You to plasma533 For This Useful Post:
    filutek (5th December, 2015)
  8. #5
    filutek's Avatar
    Silesia
  9. #6
    UK East
  10. #7
    filutek's Avatar
    Silesia
    Nobody read the BCM?
  11. #8
    UK East
    turns out I cant read them myself... doh
  12. #9
    filutek's Avatar
    Silesia
    Why the problem?
  13. #10
    forget
    eprom is crypted
    I know how to decrypt but i must know key ( i know only 2 keys )
    I have over 20 dumps and every dump has different key
  14. The Following User Says Thank You to aceton For This Useful Post:
    filutek (9th December, 2015)
  15. #11
    filutek's Avatar
    Silesia
    I know that the key to decrypt the encrypted is nec.
    How could you send me the files complete with EEPROM and NEC with a known code is try to figure it out.
  16. #12
    filutek's Avatar
    Silesia
    I am looking for further solutions
  17. The Following 2 Users Say Thank You to filutek For This Useful Post:
    Igor64 (23rd May, 2017), yellowstilo (30th August, 2018)
  18. #13
    TPS's Avatar
    you are right .
    do you have onother set , dumps with or without code from BCM corsa D ?
    regards
  19. The Following User Says Thank You to TPS For This Useful Post:
    filutek (12th December, 2015)
  20. #14
    filutek's Avatar
    Silesia
    So it needs the files to a known code for testing.
  21. #15
    TPS's Avatar
    I find many locations of PIN and many algo for different files and modules for OPEL cars , but I have no eyes now , and stopped finding anymore .
    If you want I can try to help you with PIN for set / files , without known PIN .
    More on PM
    regards
