Genuine Zgemma H.2S, question and advice.
It was something I read on another forum to cure this problem and something I always do when setting up a new box, it might fix exhumed's problem but it might just be the fact these boxes are so new that the firmware images have some bugs in them.That is not required for recording. Ext3 and 4 are only required for linux functions but the hdd can also be formatted to fat32 for recording functions however if you choose to initialise the hdd through the menu system it will automatically be formatted to ext4Comment
yes martin it was the first thing I done, when I tried to timeshift it said error timeshift cannot work as hardrive is using ext4...so then I thought aaaah must be an icompatibility with ext4 and timeshift so for timeshift to work the hardrive needs to be ext3 only so I reformatted again for it still not to work although I don't get an error now it just doesn't work.. so strange, as with other boxes I've set up before (Gigablue Quad plus, vu solo 2, ect) it just works, one frustrated man here atm,Comment
umm something I haven't tried yet is using fat32....but jeez in the year 2015 I'm having to format a 2tb external hd to fat32 just to record?
but like martin said this may be a bug, think I should go on the zgemma forums to see if anyone else is having problems?
Exhumed, can't believe I'm about to say this, but perhaps it's time to try another image ie openvix or HD freaks and see if there's any difference.
You could this HD freaks backup image by thomas88, it's not mine so can`t help with any questions on setting it up post flashing but I'm sure you'll manage.
[CODE]http://www.megafileupload.com/mmQ7/zgemma.rar[CODE]
Password: qwertyComment
Lol, don't know only tried Openatv and Openvix, but what you've got to lose, the image is made for the H2S so if it works, you could then build you own image using a vanilla HD freaks image and plugins of your choice.Comment
Courtesy of digicon, Official Zgemma Images are:
OpenATV
OpenHDF
Opendroid
Openspa
Eurosat
Italysat
vix4e2 was supported to, but I think they've withdrawn there support now.Comment
Italysat, hdfreaks & openatv are three fully supported images I think there is another one but i can't remember of the top of my head. Vix is patched so is likely to have the odd issueComment
It may not be formatting or mounting correctly. Did the op check the mountpoints to ensure it's there if it is visible then maybe try formatting with a third party to ext4 or 3. minitool partition wizard is a decent free oneComment
Hi H.H, yes I did check to make sure it was mounted and was visible and had loads of available space, I think a thirdparty tool to format may be a good idea, maybe its a bug in openatv? either way quite frustrating, but then I guess that's the fun with enigma 2, is getting the right image, but from setting up my friends zgemma single core it didn't crash once! so maybe teething problems as I think this new box isn't that old?Comment
I have an h2 that won't initialise or format drives/usb sticks. It tells you it has but it lies. I format them in my quad+ or my uno and then plug them in job done
btw all the boxes are running openatv
