Results 1 to 4 of 4
    Default help dpf off doblo 1300 multijet
    doblo_Mjt orig.zipSave my fist help dpf off 1300.multijet doblo.thnaks 1000
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    read ECU in BDM ...
    send Flash or MPC
    ..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
    I thank her for her willingness to attach the file.
    mihaiservice's Avatar
    http://www.quick-tuning.com
    Prego seniore ! first you have to reset dpf ash value also dont forget to disconnect differential pressure sender !
    Fgtech will calculate chk when writing !
    Full WinOLS user
    Custom ENG/GER OLS file for ​ Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
  5. The Following User Says Thank You to mihaiservice For This Useful Post:
    topcar2007 (8th December, 2015)
