Results 1 to 15 of 16
    makura's Avatar
    Default IPAD RESET FROM ICLOUD
    Hi Guys
    I have a Ipad that i got from a client of mine some time ago,to cut a long story short,i repaired his car and he did not have enough to pay for the job and he left his ipad and promised to come and pay my balance.
    I put the ipad away in one of my drawers and forgot about it and now 9 months down the line i see it and try to call the guy but his number is no longer in use.I am not sure if he has simply changed his number or has left the country or God forbid dead.
    Now i want to give the ipad to my daughter after some very good results in school i discover the thing is locked with find my phone in icloud.
    Question is how do i get this thing to work as i have exhausted all means to contact this guy to at least reset or remove it from his icloud account.All he gave me was his pass code to use the unit but i cant download any apps as i dont know his email and pass.
    DK Veteran johnboy1974's Avatar
    glasgow
    Nothing you can do with it with his details on it. How do you know he hasn't removed it from his iCloud account already. Connect to iTunes and restore the device. Get yourself an account with iTunes and put your details in when asked to during the restore process, you've got nothing to lose.
    makura's Avatar
    I have tried that but it says enter pass for email e****@***.co.za,no matter how many times i have tried to restore the device as soonas the updating of the device is complete his email account pops up all the time.
    glasgow
    Quote Originally Posted by makura View Post
    Then there is nothing you can do until it's removed from his iCloud account. I've not heard of any way around this security as of yet!
    Youneselm's Avatar
    Nov 2010
    i can do it on some, but you lose mobile internet, all other works.
    after scratching my head for some hours, i found solution for my one iPad that i buy second hand.
    pm me for more details or Skype: elmo-engineering
    br
    Aug 2013
    uk
    Ipad icloud removal can be done.
    Wifi only aswell. Get nand memory from ali express with clean serial remove old nand of main board replace with nand you bought. Restore.. hey presto.
    Risk of damage to main board when removing nand..
    Sometimes damage nand too much heat.
    Options are there if you know how.
    Jun 2016
    Quote Originally Posted by thayer201 View Post
    As I know It doesn't work.
    Feb 2016
    Is there any video tut ? And an empty nand is ok ?
    Aug 2013
    uk
    Quote Originally Posted by TesterSonic View Post
    sent pm - with links and tuts.
    if it helped dont forget thanks.
    If i helped.... please dont forget to press the THANKS + REP buttons .
    didi_du_93000's Avatar
    France Paris
    You must change 3 chips from the PCB!!!
    SSD NAND Flash
    CPU
    FLASH
    3 are paired together.
    Hard job because it's BGA technologie.
    If you haven't automatic alignment tool forget this job.
    https://youtu.be/TonGnxOlBp4
  11. The Following User Says Thank You to didi_du_93000 For This Useful Post:
    Meat-Head (30th March, 2017)
  12. #11
    France Paris
  13. The Following User Says Thank You to didi_du_93000 For This Useful Post:
  14. #12
    Jan 2017
    Quote Originally Posted by johnboy1974 View Post
    i wanted to type in, the exact same. I think this would def be a solution!
  15. #13
    Dec 2017
    hi
    search on YouTube .... ipad resistor
    desolder it , connect with iTunes ...
    get new Firmware ...
    be lucky
  16. #14
    Apr 2017
    Nairobi
    Hi,did you ever get help if yes which one worked ? Thanks
  17. #15
    May 2013
    Manchester
    To remove icloud from ipad you need a icloud free SN and then write to the NAND chip. You dont have to change any other chips. on ipad sn only stored on nand chip.
  18. The Following User Says Thank You to mobileunlockers For This Useful Post:
    Galee (3rd January, 2019)
