Results 16 to 30 of 44
  1. #16
    Apr 2012
    Wonderland
    interested
  2. #17
    Junior Member unu1's Avatar
    Oct 2017
    Hi All
    I repair this module i can repair your file bad .. contact me pm.
  3. #18
    Aug 2020
    Hello, you have a PM
  4. #19
    veneto
    if it matters ...
    I repair a blue&me on Fiat fiorino 1.3mj with part code 51943247 with traces of oxidation .
    after having deoxidized it, the module received power but was not detected by the car.
    Unsoldered flash memory MT29F01..... and reballed, proxi alignment with Examiner or other diag and it works perfectly.
  5. The Following 6 Users Say Thank You to orx For This Useful Post:
    alexandr1966 (23rd January, 2021), ascotauto (18th August, 2022), BusCan (14th May, 2023), lwd11 (1st September, 2020), Meat-Head (30th January, 2021), _estima_ (9th September, 2020)
  6. #20
    alclot's Avatar
    Melee Island
    Default ** Blue&ME - reboot or restart or Reset **
    Hi mates,
    I’m interested on this kind of unit.
    Can I use donor one just doing proxy on car?
    If anyone can help how to fix I appreciate it.
    Thanks in advance
  7. The Following User Says Thank You to alclot For This Useful Post:
  8. #21
    veneto
    Quote Originally Posted by alclot View Post
    Hi mates,
    Thanks in advance
    check part code donor unit compatibility with unit mounted in your car , do the proxy alignment and close the job with follow the voice prompts.
  9. The Following User Says Thank You to orx For This Useful Post:
    alclot (9th September, 2020)
  10. #22
    Nov 2018
    Hello I need dump file for NQ278 (51989250) If somebodey have good dump file from ok board please tell me here or sent me pm... Im willing to pay for dump if need...Tnx
  11. #23
    Nov 2018
    someone ?? Im willing to pay if needed no more of 50$ please... I know that everything cost but I only try to find firmware for my ecu
  12. #24
    asliyucegsm's Avatar
    turkiye
    my friend, I encountered such a problem, I removed the battery poles and waited 20 minutes again everything is fine fiat punto model
    this error is in chronic fiat models
    asliyucegsm car and laptop chipset repair
    asliyuce_elektronic
    Electronic circuit boards and motherboard repair
  13. The Following User Says Thank You to asliyucegsm For This Useful Post:
    catalinosonesti (27th December, 2020)
  14. #25
    veneto
    Quote Originally Posted by centrohifi View Post
    friends ... do you have new information on how to awaken this control unit ?? just replacing the NAND BGA ?
    just reball emmc 63 pin or if it's damaged replace , usually is brand Micron
    for reprogramming you needed firmware dump from donor board or from babbo natale:
    universal programmer RT809H with 63 pin adapter
  15. The Following 2 Users Say Thank You to orx For This Useful Post:
    audiopoint (23rd April, 2021), hbt (10th February, 2022)
  16. #26
    Meat-Head's Avatar
    These are crap modules always packing up after flat battery
  17. The Following User Says Thank You to Meat-Head For This Useful Post:
    alclot (1st February, 2021)
  18. #27
    metallo's Avatar
    Jun 2018
    Italy
    Maybe this can help, this is the blue and me boot, "broken blue and me" as you can see nand flash sectors cannot be read.
    Microsoft Windows CE NAND X-Loader (IO impedance < 50 ohms) Blk1 for Lauberhorn built Apr 16 2012 at 18:23:08
    ..............................B................................
    BLDR: power-on (built Mar 30 2012 19:33:56)
    measuring vbatt...
    vbatt: 97 (valid)
    vbatt is valid; proceeding with boot
    FMD_Init: internal 4-bit ECC enabled, Blk 1 with IECC
    Microsoft Windows CE Boot Loader Version 2.0 (Built Mar 30 2012 19:33:52)
    Board C1 128MB @12V Revision 4 - Wake up by IRQ
    Will try load OS...
    Windows CE on ARM
      Memory size: 0x04000000
      Stack Pointer: 0x00007ffc
    Value of ID Code Reg of CP15 :
    0x41069265
    Value of Control Reg of CP15 :
    0x00051078
    Value of SRC Base Address  :
    0x101fb018
    Value of SRC Control Reg :
    0x0000a9a4
    Value of CPSR :
    0x60000093
    Value of SRC PLL Control Reg :
    0x00000003
    Value of SRC PLL Freq Control Reg :
    0x00000070
    Value of SRC XTAL Control Reg :
    0x00000004
    Value of SRC Peripheral Clock Enable Status  Reg :
    0x00000000
    endmessage
    0000000000 Windows CE Kernel for ARM (Thumb Enabled) Built on Aug  4 2010 at 14:23:58
    0000000000 INFO:OALLogSetZones: dpCurSettings.ulZoneMask: 0xb
    0000000000 Daisy TX: 0x20
    0000000000 Daisy RX: 0xdda8c0
    0000000000 Daisy TX: 0xdda1a0
    0000000000 Enable WatchDog via Daisy
    0000000000 Daisy TX: 0xddb180
    0000000000 Daisy RX: 0xdda980
    0000000000 Using 128MB RAM
    0000000032 FMD_Init: Maker=2C Device=A1 Id=80-15-82
    0000000032 FMD_Init: UniqueID=c233e23b38792005
    0000000035 FMD_Init: internal 4-bit ECC enabled, Blk 1 with IECC
    0000000043 NODECARTESIO: CanDataRequest failed: Try to STOP/START the controller
    0000000051 **** CAN Bus Active ****
    0000001146 DSS: DSS_Init
    0000001406 GPIODRV: Registered pin 114 with name CAN0
    0000001407 GPIODRV: Registered pin 97 with name CAN0
    0000001410 GPIODRV: Registered pin 103 with name CAN0
    0000001429 **** Power Manager: Key On event at 12:00 of 01/Gen/2006 ****
    0000001434 CAN!Bus 0 Key On
    0000001434 PowerPolicyNotify(PPN_CAN_ON, 0)
    0000001717 Voltage Value At Which LAUBERHORN is Supposed to Suspend Now (<6V): 0x2c
    0000001718 Voltage Value At Which LAUBERHORN is Supposed to Suspend After One Hour 16V <= Voltage < 24V : 0x87
    0000001728 Voltage Value At Which LAUBERHORN is Supposed to Suspend After One Minute 24V <= Voltage : 0xc1
    0000001909 Starting kicking Watchdog!
    0000002026 WAVEDEV:  0x00000002  LOGZONE_ERROR
    0000002026 WAVEDEV:  0x00000004  LOGZONE_WARNING
    0000002029 WAVEDEV:  0x00000008  LOGZONE_SETTING
    0000002038 WAVEDEV: HardwareContext::Init() Msp Audio
    0000002044 WAVEDEV: HardwareContext::Init() Msp BtPCM
    0000002069 WAVEDEV: PowerDown Codec
    0000002342 ERROR: OALIoCtlHalGetDeviceInfo: Device doesn't support IOCTL_HAL_GET_DEVICE_INFO::SPI_GETBOOTMENAME
    0000002453 ERROR: OALIoCtlHalGetDeviceInfo: Device doesn't support IOCTL_HAL_GET_DEVICE_INFO::SPI_GETUUID
    0000002514 OTG Transceiver: VendorId=0x04cc ProductId=0x1508
    0000002525 OTG Transceiver: VendorId=0x04cc ProductId=0x1508
    0000002525 Function=45 Interface=60 Control=c6
    0000002530 UsbFn: 01
    0000002537 Rising=00 Falling=00 Status=0b Latch=00
    0000002537 Debug=00 CarKit=00 Power=00
    0000002546 UsbHcd1!SetPowerState: D0 -> D4
    0000002569 BtHCI:  +++ HCI_Init +++  (v.1102; LOGZONE=0xFFF7FFFF)
    0000002570 BtHCI:  0x00000001  LOGZONE_TRACE
    0000002574 BtHCI:  0x00000002  LOGZONE_ERROR
    0000002578 BtHCI:  0x00000004  LOGZONE_WARNING
    0000002586 BtHCI:  0x00000008  LOGZONE_SETTING
    0000002586 BtHCI:  0x00002000  LOGZONE_MEDIA
    0000002590 BtHCI:  0x00008000  LOGZONE_RIL
    0000002598 BtHCI: Addr is [0014092bb9d8]
    0000002599 BtHCI: Image type is Product
    0000002616 BtHCI:  --- HCI_Init --- rc=1
    0000002622 BtHCI:  +++ HCI_SetPower (D0->D4) +++
    0000002622 BtHCI:  --- HCI_SetPower ---
    0000002643 ICI!SetPowerState: D0 -> D4
    0000002679 GPIO_EnableAltFunction::GPIO_ALT_UART_2
    0000002761 ERROR: IECC uncorrectable flash read error on sector 15034: status 0x61
    0000002763 Error FlashPddHelper::ReadPhysicalSectors@305:
    0000002768 FlashPdd::ReadPhysicalSectors failed for sectors (0x3aba, 0x1).  Result = 31.
    0000002777 Error FlashMddWrapper::IoControl@214:
    0000002780 FlashMddWrapper::IoControl - ReadWriteLogicalSectors() failed.
    0000002794 Error FlashPartitionDriver::IoControl@366:
    0000002794 FlashPartitionDriver::IoControl() - ReadLogicalSectors failed (31).
    0000002805 Exception 'Undefined Instruction' (1): Thread-Id=016c0002(pth=8fd559d8), Proc-Id=00400002(pprc=8876b308) 'NK.EXE', VM-active=00400002(pprc=8876b308) 'NK.EXE'
    0000002818 PC=c0706088(iso15765.dll+0x00006088) RA=c01b49d0(k.coredll.dll+0x000249d0) SP=d26be880, BVA=00000000
    0000003131 L2CAP EstablishDeviceContext - fixing old structure registration
    0000003134 BtHCI:  ===HCI_StartHardware===
    0000003251 BtHCI:  +++ HCI_OpenConnection (D4)+++
    0000003251 BtHCI:  --- HCI_OpenConnection ---
    0000003383 ERROR: IECC uncorrectable flash read error on sector 13999: status 0x61
    0000003385 Error FlashPddHelper::ReadPhysicalSectors@305:
    0000003390 FlashPdd::ReadPhysicalSectors failed for sectors (0x36af, 0x1).  Result = 31.
    0000003398 Error FlashMddWrapper::IoControl@214:
    0000003402 FlashMddWrapper::IoControl - ReadWriteLogicalSectors() failed.
    0000003415 Error FlashPartitionDriver::IoControl@366:
    0000003415 FlashPartitionDriver::IoControl() - ReadLogicalSectors failed (31).
    0000003426 ERROR: IECC uncorrectable flash read error on sector 13999: status 0x61
    0000003429 Error FlashPddHelper::ReadPhysicalSectors@305:
    0000003434 FlashPdd::ReadPhysicalSectors failed for sectors (0x36af, 0x1).  Result = 31.
    0000003442 Error FlashMddWrapper::IoControl@214:
    0000003446 FlashMddWrapper::IoControl - ReadWriteLogicalSectors() failed.
    0000003468 Error FlashPartitionDriver::IoControl@366:
    0000003468 FlashPartitionDriver::IoControl() - ReadLogicalSectors failed (31).
    0000003476 Exception 'Undefined Instruction' (1): Thread-Id=016c0002(pth=8fd559d8), Proc-Id=01410006(pprc=8fcfaac0) 'udevice.exe', VM-active=01410006(pprc=8fcfaac0) 'udevice.exe'
    0000003494 PC=414ea100(ws2.dll+0x0000a100) RA=40054280(coredll.dll+0x00024280) SP=0008fb1c, BVA=00000000
    0000004521 ERROR: IECC uncorrectable flash read error on sector 13999: status 0x61
    0000004522 Error FlashPddHelper::ReadPhysicalSectors@305:
    0000004528 FlashPdd::ReadPhysicalSectors failed for sectors (0x36af, 0x1).  Result = 31.
    0000004535 Error FlashMddWrapper::IoControl@214:
    0000004540 FlashMddWrapper::IoControl - ReadWriteLogicalSectors() failed.
    0000004555 Error FlashPartitionDriver::IoControl@366:
    0000004555 FlashPartitionDriver::IoControl() - ReadLogicalSectors failed (31).
    0000004566 ERROR: IECC uncorrectable flash read error on sector 13999: status 0x61
    0000004568 Error FlashPddHelper::ReadPhysicalSectors@305:
    0000004574 FlashPdd::ReadPhysicalSectors failed for sectors (0x36af, 0x1).  Result = 31.
    0000004581 Error FlashMddWrapper::IoControl@214:
    0000004586 FlashMddWrapper::IoControl - ReadWriteLogicalSectors() failed.
    0000004600 Error FlashPartitionDriver::IoControl@366:
    0000004600 FlashPartitionDriver::IoControl() - ReadLogicalSectors failed (31).
    0000004612 Exception 'Undefined Instruction' (1): Thread-Id=016c0002(pth=8fd559d8), Proc-Id=01410006(pprc=8fcfaac0) 'udevice.exe', VM-active=01410006(pprc=8fcfaac0) 'udevice.exe'
    0000004626 PC=414ea100(ws2.dll+0x0000a100) RA=40054280(coredll.dll+0x00024280) SP=0008fb1c, BVA=00000000
    0000005466 **** CAN Bus Error Pasive Detected****
    0000005649 ERROR: IECC uncorrectable flash read error on sector 13999: status 0x61
    0000005650 Error FlashPddHelper::ReadPhysicalSectors@305:
    0000005656 FlashPdd::ReadPhysicalSectors failed for sectors (0x36af, 0x1).  Result = 31.
    0000005664 Error FlashMddWrapper::IoControl@214:
    0000005668 FlashMddWrapper::IoControl - ReadWriteLogicalSectors() failed.
    0000005692 Error FlashPartitionDriver::IoControl@366:
    0000005692 FlashPartitionDriver::IoControl() - ReadLogicalSectors failed (31).
    0000005702 ERROR: IECC uncorrectable flash read error on sector 13999: status 0x61
    0000005706 Error FlashPddHelper::ReadPhysicalSectors@305:
    0000005710 FlashPdd::ReadPhysicalSectors failed for sectors (0x36af, 0x1).  Result = 31.
    0000005718 Error FlashMddWrapper::IoControl@214:
    0000005723 FlashMddWrapper::IoControl - ReadWriteLogicalSectors() failed.
    0000005738 Error FlashPartitionDriver::IoControl@366:
    0000005738 FlashPartitionDriver::IoControl() - ReadLogicalSectors failed (31).
    0000005746 Exception 'Undefined Instruction' (1): Thread-Id=016c0002(pth=8fd559d8), Proc-Id=01410006(pprc=8fcfaac0) 'udevice.exe',
  19. The Following 4 Users Say Thank You to metallo For This Useful Post:
    alexandr1966 (15th March, 2021), marcobh5 (13th February, 2021), Meat-Head (3rd February, 2021), orx (5th February, 2021)
  20. #28
    Dec 2017
    South American
    anyone can read this micro?
  21. #29
    Feb 2019
    Nederland
    Anyone can repair bad file from MICRON NQ278 , MT29F1G08ABBDAH4-IT (51944597 Blue & Me module from fiat doblo 2013).how much is ,prices?
    Regards,
  22. #30
    Nov 2018
    Quote Originally Posted by metallo View Post
    measuring vbatt...
    vbatt: 97 (valid)
    Will try load OS...
    Windows CE on ARM
    0x41069265
    0x00051078
    0x101fb018
    0x0000a9a4
    Value of CPSR :
    0x60000093
    0x00000003
    0x00000070
    0x00000004
    0x00000000
    endmessage
    how you read all this information... its a bin file... how you open ?
