Results 1 to 5 of 5
    twchnodictator's Avatar
    Aug 2015
    European Union
    Default VW GOLF 4 1.9 TDI MAF to MAP
    Hi mates,
    Can somebody turn off MAF sensor and turn all setting to MAP sensor? MAF will be removed.
    My friend is building pocket rocket from old golf so we need your help mates.
    File here Attachment 346173
    Thanks for your time and help!
    P.S. Thanks + Reputation guarantee
    Nov 2013
    Romania
    Default maf to map
    change was made, only that there is something wrong! turbine is stock? if yes then set pressure is very high and unnecessarily!WinOLS ( (Volkswagen.rar
  3. The Following User Says Thank You to adyzamfir For This Useful Post:
    twchnodictator (11th December, 2015)
    Andrei2015's Avatar
    Oct 2015
    I like svbl- 2800mbar
    Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
    VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
    POPS & BANGS (Schubabschaltung, Crackles)
    on allmost every petrol
  5. The Following User Says Thank You to Andrei2015 For This Useful Post:
    CustomCars (10th December, 2015)
  6. #4
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    Maybe they have additional injector mechanical steering so then will be enough fuel for that boost :-)
    Aug 2015
    European Union
    Quote Originally Posted by adyzamfir View Post
    Thanks for that mode, mate! Turbo non stock, injectors also, pump rebuilt, custom exhaust and a lot of mods.
