locarno (17th December, 2015)
egr off. no passWinOLS (Ford Fusion (egr off) - ).rar
Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
POPS & BANGS (Schubabschaltung, Crackles) on allmost every petrol
ali kaptan (24th September, 2021), CIONUT (26th March, 2017), ecutuners (12th December, 2015), kasim_izmir (1st February, 2023), locarno (17th December, 2015), navatar (4th October, 2017), tecnocar (7th July, 2017), tytano1 (20th December, 2017), whim (20th January, 2020)
DTC 1412 appeared after few days.
EGR is plugged.
Here is 100% worked solution!
bobolin4o (22nd December, 2015)
EGR should be unplugged or not ?
P0406 appeared after EGR unplugg.
Were there any Egr faults / Egr dtc on the car already?
Sent from my SM-G900F using Tapatalk
locarno (21st December, 2015)
Before EGR off ? Only P1412. I was able to clear it using diagnostic but, then appeared again after few days.
P0406 appear after EGR unplug and can't be cleared using diagnostic.
I tried remove DTC with "MTX DTC Remover" , but DTC's are still enabled. It does not work with this ECU.
Any ideas ?P1412 - EGR valve frozen
P0406 - EGR Sensor A Circuit High Input
what if you leave egr connector on?
zekiko (24th December, 2017)
I also want the modified file
