Results 1 to 12 of 12
    Oct 2014
    Poland
    Default Ford Fusion 1.4 TDCI - SID804 - EGR off
    SID804
    Please help with egr off
    takiKolo's Avatar
    Sep 2015
    POLAND
  3. The Following User Says Thank You to takiKolo For This Useful Post:
    locarno (17th December, 2015)
    Andrei2015's Avatar
    Oct 2015
    Default egr off
    Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
    VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
    POPS & BANGS (Schubabschaltung, Crackles)
    on allmost every petrol
  5. The Following 9 Users Say Thank You to Andrei2015 For This Useful Post:
    ali kaptan (24th September, 2021), CIONUT (26th March, 2017), ecutuners (12th December, 2015), kasim_izmir (1st February, 2023), locarno (17th December, 2015), navatar (4th October, 2017), tecnocar (7th July, 2017), tytano1 (20th December, 2017), whim (20th January, 2020)
  6. #4
    Oct 2014
    Poland
    DTC 1412 appeared after few days.
    EGR is plugged.
  7. #5
    Jan 2010
    Bulgaria
    Here is 100% worked solution!
  8. The Following User Says Thank You to oem For This Useful Post:
    bobolin4o (22nd December, 2015)
  9. #6
    Oct 2014
    Poland
    EGR should be unplugged or not ?
    P0406 appeared after EGR unplugg.
  10. #7
    furburger
    Guest
    Were there any Egr faults / Egr dtc on the car already?
    Sent from my SM-G900F using Tapatalk
  11. The Following User Says Thank You to furburger For This Useful Post:
    locarno (21st December, 2015)
  12. #8
    Oct 2014
    Poland
    Before EGR off ? Only P1412. I was able to clear it using diagnostic but, then appeared again after few days.
    P0406 appear after EGR unplug and can't be cleared using diagnostic.
    I tried remove DTC with "MTX DTC Remover" , but DTC's are still enabled. It does not work with this ECU.
    P1412 - EGR valve frozen
    P0406 - EGR Sensor A Circuit High Input
    Any ideas ?
  13. #9
    Andrei2015's Avatar
    Oct 2015
    what if you leave egr connector on?
  14. The Following User Says Thank You to Andrei2015 For This Useful Post:
  15. #10
    Oct 2014
    Poland
    Quote Originally Posted by Andrei2015 View Post
    As I wrote previously.
    Quote Originally Posted by locarno View Post
    EGR is plugged.
    Actually it is cleared using diagnostic. We will see after few days. Maybe it was old DTC stored in memory.
  16. #11
    May 2010
    ITA
    flash the map and after disconnect the EGR , right?
  17. The Following User Says Thank You to weekdgl For This Useful Post:
    zekiko (24th December, 2017)
  18. #12
    Dec 2017
    I also want the modified file
