Results 1 to 5 of 5
    Nov 2013
    Default change n75 map vnt to wastgate map
    could somebody change the n75 map to a wastgate n75 map?
    its for my tdi agr.
    thanks a lot038906018AP VNT.rar
    Jul 2014
    Lithuania
    Emm, n75 is a VGT turbo and the actuator is controled via n75
    A normal wastgated turbo uses it's owns turbo pressure to adjust the actuator.
    Or maybe I didin't understand your question correctly...
    Dec 2015
    If I don't mistake there is a switch to say that the turbo is a WG one and not a VGT. After that it will work (with some modification on the N75 one of course)
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    okok man, but what you want change ? Pls explain what to do...
    want change VTG to WG yes?
    All brand FileService - Custom - remapping company
    POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
    | Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
    Nov 2013
    I have a 038906018BL 1.9 TDI AGR with WG
    Now i have a ABT TUNING ecu from a 038906018AP this is a VNT ecu.
    The runs great with ecu only on boost i have a wave boost. Thats why i want to change the n75 map.
