Results 1 to 13 of 13
    Dec 2015
    Terceira island, Azores, Portugal
    Question Isuzu Dmax 2.5 2007 4JK1. need EGR OFF, what TOOL/SOFTWARE to use via BDM.
    Hello to all,
    I have a Isuzu Dmax 2.5 (not 3.0), 136hp, 2007, engine 4JK1, with ECU Delphi 8980173488 28080142.
    Bad EGR! Need help on selecting the hardware & software to fix/remove it, so i'm here for help!
    Was thinking on using KTAG clone for BDM job.
    Could anyone help me with this issue???
    Thank you all.
    jtbf
    Dec 2015
    Found 2 KTAG's (clone), one V2.11 & V 2.13.
    Read somewhere that V 2.11 is better then V 2.13, can anybody confirm this???
    Thanks.
    jtbf
    Dec 2015
    Default Hellooooo??? Anybody out there????
    No one worked with a Delphi ECU from Isuzu D max 2.5 136hp 2007??? Hard to believe...
    Thank you all anyway!!!
    jtbf
    Quote Originally Posted by jtbf View Post
    Thanks.
    jtbf
    moky's Avatar
    Behind you
    your ktag are bad,good ktag make delphi ecu without problem..you are not lucky with clone chinese lottery..!
    try with kess to read write ecu
    Dec 2015
    What hardware/software do you recomend to delete EGR on this Isuzu 2,5 delphi ECU?? Can be done only via BDM, from what i've heard...
    Thanks.
    Dec 2015
    For this delphi ecu, i think that BDM is the only way...
    Quote Originally Posted by figo95 View Post
    Dec 2015
    Hello again,
    just to let you know that Ktag V 2.10 (clone) works great via BDM on Delphi ECU (Isuzu dmax 2,5 2007).
    Regards.
    Dec 2015
    Hello you all!
    Just wrote the new map on my Isuzu dmax 2,5 2007, delphy ECU (via bdm, ktag v2.10 clone), but i still get an error code PO406 EGR sensor high voltage.
    Had to install a 50k ohm resistor on the egr sensor to simulate a steady egr position, since the one on the egr is bad. The only problem is that i have a permanent error code and still did not find a solution for this issue.
    Does anyone have a idea how to fix this situation???
    Best Regards.
    jtbf
    Oct 2013
    GB
    hello to all DK experts i want to read this Delphi ECU from Isuzu Dmax 2.5 can anyone tell me which BDM adapter must i use wiith Ktag.
    Thanks in advance.
    Dec 2015
    KTAG V2.10 clone, via BDM.
    Cable 144300T 100
    Adaptor P-D94V-0
    Do not forget to connect the negative to the ECU lower terminal...
    It works great!
    Someone changed the ECU file for me, and i wrote it back to the ECU, deactivating the EGR, and adding 25 hp (great change). Installed a blanking plate on EGR.
    Did not want more then 25 hp, want the engine to less a few more years with no side problems...
    The only issue that i can not fix is that my egr sensor is bad, and i had to install inline a 50k ohm resistor to simulate asteady egr position, but the ecu still has a permanent error code of high egr sensor voltage. I'm still waiting for a potentiometer to play with it, and try to find the ideal resistance (ohms) and try to clear this code.
    This is the only issue that i have so far, and still no luck fixing it.
    Regards.
    jtbf
  12. The Following User Says Thank You to jtbf For This Useful Post:
    nikostzimis (20th March, 2016)
  13. #12
    Caribbean
    Cable 144300T 100
    Adaptor P-D94V-0
    It works great!
    Regards.
    jtbf
    check your pm friend
  14. The Following 2 Users Say Thank You to S.W.A.M.I For This Useful Post:
    nikostzimis (20th March, 2016), youssef70 (29th October, 2016)
  15. #13
    Sep 2010
    Turkey
    Cable 144300T 100
    Adaptor P-D94V-0
    It works great!
    Regards.
    jtbf
    i am trying to read this ecu with 14AS00T01S adaptor but no luck
    wich is the P-D94V-0 adaptor i can not find it any help please ?
