help please
help please
any software version ? upload original file
Full WinOLS user
Custom ENG/GER OLS file for Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
wait i send you
ok this my ori file thank youorimap.rar
Your file only original not are,Volta all the time are erased 90% of dtc table, your file are now erased by a smart brain to 99%,only 5 dtc remain in the file
i have edit your file but not from original becouse are mising from my database,from other a class 82hp
write the file and disconnect differential pressure sender also plug from egr !
Please report !
Full WinOLS user
i try but is possible write another file inside my ecu?Because maybe map inclueded also key code? but i try immediately and thank u so much.
Mate If you write other file from different ecu not the some SW. Better drive to near Mercedes service.
Just write the file,all will be fine !
Also all this kind of ecu from old A,C,E Claas can be updated in "offline" mode,dont need any "call" to local dealer !
Full WinOLS user
