Results 1 to 10 of 10
    Jul 2010
    Default alpine vel satis code required
    after reading many posts on these . I am still confused !
    I have alpine head unit MH9RN910 01 serial no AL9RN1P0214727 . this is faulty original unit . I need code for this so I can swap panel eep to good 2nd unit . I have attached dump for Philips tuner unit . can someone work out panel code from this 24c32 dump ? code for tuner is 3824 I think .
    thank you friends
    please add rep & thanks if my post was helpful
    Feb 2010
    WALES
    Quote Originally Posted by sparkle View Post
    thank you friends
    Your code is 3824
    wbr
  3. The Following 2 Users Say Thank You to shooting For This Useful Post:
    REZON (14th December, 2015), sanixmen (15th December, 2015)
    sanixmen's Avatar
    Aug 2015
    Hi, code is: 3824
  5. The Following 2 Users Say Thank You to sanixmen For This Useful Post:
    clydey (14th December, 2015), REZON (14th December, 2015)
  6. #4
    Raimax's Avatar
    Nov 2013
    LT
    code has already been written by SPARKLE
  7. The Following 3 Users Say Thank You to Raimax For This Useful Post:
    clydey (14th December, 2015), REZON (14th December, 2015), sanixmen (15th December, 2015)
  8. #5
    KierAn20's Avatar
    Sep 2009
    UK
    Post the 24c01 dump from the front panel of the good replacement cd changer unit, then no need to change eeproms over mate.....
  9. The Following 4 Users Say Thank You to KierAn20 For This Useful Post:
    clydey (14th December, 2015), mcd76 (14th December, 2015), REZON (14th December, 2015), shooting (14th December, 2015)
  10. #6
    Jul 2010
    attached is original panel 24c01 dump . I am so confused still ! I thought the panel code could be read from tuner 24c32 dump ?
    thank to all who replied but I have tuner code ............I just need panel code of original to swap eep to 2nd hand cd changer . will this work ?
  11. #7
    KierAn20's Avatar
    Sep 2009
    UK
    Panel code is also 3824 mate.
    The way I do these is rather than changing the front panel eeprom or clone dump. Just read the front panel 24c01 of the replacement changer - to find out its code. Then plug new changer in without changing any dumps on it, enter code and you're up and running
  12. The Following 8 Users Say Thank You to KierAn20 For This Useful Post:
    arık (15th December, 2015), clydey (15th December, 2015), ilen (15th December, 2015), mcd76 (15th December, 2015), Raimax (15th December, 2015), REZON (15th December, 2015), sanixmen (15th December, 2015), sparkle (6th January, 2016)
  13. #8
    Jul 2010
    thank you KierAN20 . CODE is correct !
  14. The Following 2 Users Say Thank You to sparkle For This Useful Post:
    KierAn20 (6th January, 2016), shooting (6th January, 2016)
  15. #9
    Jan 2017
    Lithuania
    help with code from 6cd changer
    alpine MH9RN910 01
    radio code know
  16. #10
    Jan 2017
    Lithuania
    Maybe can check or code 2616 right?
    no have car in this moment
