Results 1 to 5 of 5
    multiplex1976's Avatar
    Aug 2011
    Polska
    Default Please DPF OFF VW TOURAN 2.0tdi 03G906021GB
    Please Dpf off Touran 2.0tdi 03G906021GB edc16u
    sw: 1037378847
    Thanks regards
    Andrei2015's Avatar
    Oct 2015
    Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
    VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
    POPS & BANGS (Schubabschaltung, Crackles)
    on allmost every petrol
  3. The Following User Says Thank You to Andrei2015 For This Useful Post:
    multiplex1976 (16th December, 2015)
    May 2011
    Dear friends.
    I try to help my to brother in law. (my wife brother )
    he by passat 3c2 - there is removed DPF and chiped UP ECU. That car do a lot of smoke.
    i find on internet original map for ECU. please can you help me. need remove DPF from original VW *.bin file.
    VW_ORIG_03G906018ER.zip
    CHIPPED_UP_03G906018ER.zip
    Andrei2015's Avatar
    Oct 2015
    What color smoke has?
    May 2011
    when is with chipped bin - there are lot of dark smoke.
    with vw original file wich i try to flash - there is so much less smoke (dark, white) - i thing because temperature outside are now low.
    i need to use original file - with dissabled all dpf function. if is possible to do it.
