Page 1 of 2 12 LastLast
Results 1 to 15 of 18
    Nov 2010
    Mannheim
    Default DPF,EGR and DTC off
    I have my skoda pcr2.1 and need it with DPF and EGR off please. and there is always one fault appeared in the fault code section , this fault allow the rpm rise to 1000 and the coolant fan work when the rpm rises,
    Here is the fault cosde ,
    Address 01: Engine Labels: 03L-906-023-CAY.clb
    Control Module Part Number: 03L 906 023 NF HW: 03L 906 023 JH
    Component and/or Version: 1,6l R4 CR td H43 8799
    Software Coding: 00114036032401080000
    Work Shop Code: WSC 73430 031 00083
    ASAM Dataset: EV_ECM16TDI02103L906023NF 003005 (SK35)
    ROD: EV_ECM16TDI02103L906023NF.rod
    VCID: 77F78F9ECEAF86865A-8022
    1 Fault Found:
    14355 - Exhaust Gas Temperature Sensor; B1 S3
    P242A 00 [167] - Malfunction
    MIL ON - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 246910 km
    Date: 2007.14.24
    Time: 09:33:01
    Readiness: 1110 1000
    so will you please do it dpf and egr off , and the DTC off also?
    Regard
    Jul 2011
    EGR Actuator plug have be disconnected
  3. The Following User Says Thank You to draganelektricar For This Useful Post:
    KFZ (21st December, 2015)
    Jan 2010
    dpf off egr off p242a off
    Nov 2010
    Mannheim
    Quote Originally Posted by draganelektricar View Post
    Thank you very much and I appreciate your helpful , my question is :
    did you delete the DTC ?
    Regards
  6. #5
    Jul 2011
    dtc 242a off
  7. The Following User Says Thank You to draganelektricar For This Useful Post:
  8. #6
    Jul 2011
    yes dtc 242a dtc off..
  9. The Following User Says Thank You to draganelektricar For This Useful Post:
  10. #7
    Nov 2010
    Mannheim
    Quote Originally Posted by taraba123 View Post
    Thank you Mr. taraba123
    it worked very well and perfect ,
    well done
    Regards
  11. #8
    Nov 2010
    Mannheim
    Default sprinter dpf and egr off please
    Hi all
    I have MB sprinter , need it dpf and egr off please
    A646 150 6278
    EDC16CP31
    Regards
  12. #9
    soundnavigator's Avatar
    Sep 2010
    Only Swiftec solution is free.
    For manual and full DPF and EGR OFF solution, contact me on skype.
    pass on PM
    All full worked manual solutions - FAP/DPF OFF, Adblue/SCR OFF, EGR OFF, TVA OFF, SWIRL OFF, O2/Lambda OFF, DTC OFF and etc
    Our database available for download 24/7 on EVC server for all legal WinOLS users
  13. The Following User Says Thank You to soundnavigator For This Useful Post:
    LEANDRO SANDES TEIXEIRA (10th May, 2016)
  14. #10
    Nov 2010
    Mannheim
    Hi Mr.taraba123
    I need your help please
    I have touran with automatic ecu , will you please guide me to the solutoion?
    I have all data flash( 8-2015 ) for VAG
    and I have also ODIS for flashing . but I dont know which flash file should I choose to flash it to change it from automatic to manual,
    so will you help me ?
    in attachment you will find all data required and in Log file you find the DTC
    Regards
  15. #11
    mihaiservice's Avatar
    Dec 2009
    http://www.quick-tuning.com
    You can not solve the car with Odis by OBD ! it required entire file from ecu to be edited !
    Full WinOLS user
    Custom ENG/GER OLS file for ​ Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
  16. The Following User Says Thank You to mihaiservice For This Useful Post:
    KFZ (17th January, 2016)
  17. #12
    rdu04's Avatar
    Nov 2009
    RO
    Default sprinter dfp off
    i need help please
    mercedes sprinter engine 2.2
    Mercedes Ecu Type : BOSCH EDC16+/EDC16C
    Mercedes Hardware ID : A 0014462702
    Mercedes Hardware Number : 4005
    Mercedes Software Number : 4209
    Bosch Software Number : 1037381129
    Programming Date : 03.05.06
    need dpf off without disconect sensor
    read mpps
    thanks in advance
  18. #13
    Sep 2010
    Your file DPF OFF free.
    Press THANKS please.
    BR
  19. The Following User Says Thank You to soundnavigator For This Useful Post:
    rdu04 (22nd January, 2016)
  20. #14
    rdu04's Avatar
    Nov 2009
    RO
    thanks my friend but i need pass please
  21. #15
    gadelhas's Avatar
    Sep 2012
    Portugal
    hi dk a need dtc remove p3130 of seat ibiza 6l 1.4 tdiIBIZA 3 CILINDROS AMIGO GORDO.rar
