you don't have the ori file ? send me ecu number
Hi M8,
Post id data here I will find your ori file.
Regards.
mpps no write it safety!!!! edc15vm+ only boot mode can now restore your ecu
that not true mpps v12 or v16 work perfect with this cars i do over 100 like this with mpps and till now never have problem i use mpps for this old ecus only and WORK , and he can recover it very easy even with programmer and little soldering if cant make boot mode .
I have mpps 12 and 16 euro and use them almost every day and edc15/edc16 work like a charm but need to have battery charger and .......
Anyway give the ecu number i will give you the ori file.
Chiptuning/DPP/EGR/LAMBDA(O2)/FLAPS/Adblue/DTC OFF / EDC17 Immo OFF
Kess v2 eu. clone full/Ktag eu. Clone 6.070 full
Info on pm
Kess v2 ori , K-tag ori, MAGPro2 x17, Galleto v54 EU ,Winols ,AVDI full ori, Orange 5 /Omega /Xprog/Upa all ori , VAS Pc , Porsche PIWIS 2 and etc........
take fuse is for dash where is the immo . It say clear to remove it and read what is mpps say ,even before 2 or 3 days i make aud a4 1.9tdi edc15p over obd , and i get 3 times error without remove fuse N11 after that all great .
And yes 100% safe is to read it on programmer but mpps work with this ecus . I not know what mpps you have but i not have your problems , and let stop with this for mpps ,the point is to help him to fix his issue
regards
Info on pm
you are right. we need more info to help him. ecu type , tunfile , what is error etc.... no enought info "only golf 4 no start "
