Results 1 to 15 of 15
    ubistvo's Avatar
    SERBIA Krusevac
    Default PU2294B HELPPPPP
    OK
    I have clarion PU 2294 with 93c46 rotated
    I read eeprom and i found code and reset counter
    But every time i start the radio say "CODE IN" and after that only show this "----" and not alowe me to
    enter the code
    I try many diferent dumps but every time is ----
    What to do?
    Does anyone know???
    THANKS
    ""Just press THANKS when you think it is useful""
    WALES
    Quote Originally Posted by ubistvo View Post
    OK
    enter the code
    What to do?
    Does anyone know???
    THANKS
    Will be fault in Button panel
    wbr
    ubistvo's Avatar
    SERBIA Krusevac
    aha ok i will see for that
    No all buttons work perfectly
    Is it posibile to work without code??
    WALES
    Post your dump and I'll check it for you...
    wbr
    ubistvo's Avatar
    SERBIA Krusevac
    Here try my friend
    WALES
    Here try my friend
    And you tried 3141 ?
    wbr
    Jan 2012
    flex cable ok?
    @shooting
    first read post please
  8. The Following User Says Thank You to RadioChiP For This Useful Post:
    shooting (25th December, 2015)
    WALES
    Here try my friend
    Dump OK, must be front panel at fault..., remove front panel and examine connections..
    wbr
    (I've made an alteration to your dump to try if front panel is ok)
  10. #9
    ubistvo's Avatar
    SERBIA Krusevac
    OK
    I tested again front panel and all ok
    I will try your dump now
    shooting Not working
    Still the same fuc... sh..t
  11. #10
    WALES
    OK
    Have you got another front panel to try?
    wbr
  12. #11
    ubistvo's Avatar
    SERBIA Krusevac
    No
    I do not have
  13. #12
    WALES
    No
    I do not have
    One other thing to try is, when you replaced the panel did you re-seat the connector between the pcb and the panel?
    (To do this look beside the CD mech when the front is on and use a firm tool to press the connector back onto the front panel)
  14. #13
    ubistvo's Avatar
    SERBIA Krusevac
    Yep i try all that
    I give up for now with this
  15. #14
    dashradio's Avatar
    Inafield
    I have had one of these doing the same as yours, the only way I got it to work was with a replacement front panel.
  16. #15
    Jan 2016
    Default pu-2294
    try that pu2294B(d) 93c46 rotacja 2254 (1)http://www.eserviceinfo.com/
