Results 1 to 5 of 5
    Top Poster popi110's Avatar
    Default Zgemma S2 boot problem
    have an Zgemma S2 and updated packages but now box shows boot then just cycles through count up numbers
    have followed flash instructions
    formated usb
    put image on it in Zgemma folder
    put usb in rear
    plugged in
    held the power button etc
    still the same
    any ideas please
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    When your flashing the image on to the box, the front display will say 'usb' then when you press the power/standby button it will then say 'flash' if this doesn't happen try another USB drive.
    Also ensure as most images come as a zip file, this is correctly unzipped and only the 'zgemma' folder is placed on the USB drive.
    yep i have unzipped and only the 'zgemma' folder is placed on the USB drive. do not get as far as the display showing usb or flash thied several fat 32 formatted usb drives
    box stuck on scumnsee boot up screen and display counting up weird
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Quote Originally Posted by martin035 View Post
    will do trying low level format tool first
