Results 1 to 11 of 11
    Dec 2011
    Default Help - newbie needs to flash dm800 hd se due to error on boot
    I am needing to try and get a image onto the dm800 hdse that I have
    I have got this far but dont have an image for it or bl82 /SSL82 The sim is the original sim 2.01 that sits underneath the hard drive.
    Any kind soul out there able to help me out.
    Happy new year to you all and thanks in advance
    digicon's Avatar
    Jul 2009
    All images and latest bootloaders can be found in the Download section: HERE
    Dec 2011
    Thanks for pointing me in the right direction, I tried to install http://www.digital-kaos.co.uk/forums...o=file&id=3398 but it would not let me click flash or if I clicked flash it done nothing. It mentioned singapore but no idea if I have singapore or not.
    Can you also advise about the ssl82 / 84 and which one I need to get as I have no idea when it comes to these.
    Thanks in advance.
    This is a pic of my dm 800 hd se info:
    <a href="http://s799.photobucket.com/user/amacmo13/media/dm800%20hd%20se%20info%20with%20no%20serial%20deta ils_zpsirc43j8g.jpg.html" target="_blank"><img src="http://i799.photobucket.com/albums/yy278/amacmo13/dm800%20hd%20se%20info%20with%20no%20serial%20deta ils_zpsirc43j8g.jpg" border="0" alt=" photo dm800 hd se info with no serial details_zpsirc43j8g.jpg"/></a>
    http://i799.photobucket.com/albums/y...psirc43j8g.jpg
    http://s799.photobucket.com/user/ama...43j8g.jpg.html
    Any help is appreciated.
    digicon's Avatar
    Jul 2009
    You have Bootloader SSL79 so if you want to flash a newer image with a newer bootloader say 82a or 84d then normally the image will have the bootloader ready when being flashed on some occasions you may have to flash the bootloader separately first and then flash the image directly afterwards.
    I always Flashed my 800/800SE's with the bootloader first then the corresponding image.
    So basically i opened up a web browser flash the bootloader i wanted say 84d then without rebooting the receiver i opened a second web browser window and flashed the image and the did a reboot.
    If your still having problems you may need to use a Null modem cable or if its the 800SE use the mini flashup port which is basically a micro usb slot
    Dec 2011
    Hi thanks for helping mate, I have tried the following since you posted,
    1\ sunray flashup and it connects to the device and puts it into http mode, then when I go into the flash part I have selected a couple of different files and then click flash. When I do this it does nothing regardless of the file / browser that I pick with correct extension. I think this is because I have an error message on the front pannel of rso1 ca no found which I got after going into one of the menus to update and since that point I have been goosed.
    2\ I have since found that I can hold down the button at the back to put it into flash mode and then enter in ip address and browse for image. However it keeps saying wrong architecture. I am really lost here any chance you could link me to the files needed so I can have the latest image / boot loader as I am clearly doing something really stupid but just cant figure out what.
    Thanks in advance
    Last edited by gandalf72; 1st January, 2016 at 08:48 PM. Reason: add further reason to potential reason why 1 didnt work.
    Dec 2011
    I have managed to cure the problem partially I think, I have located the image named OpenPLi-4.0-dm800se-20151023-sim2-ssl84d.
    I am struggling to find the dm 800 se boot loader (current one was 79 but am I right in thinking I now need 84d?) sim 201 and the other file you need to flash any advice much appreciated. and thank you very much for your help so far.
    Dec 2011
    Thanks for reply, I just switched box off and then back on again and its stuck with a picture of the dm800 on the tv. On the box lcd it looks like it is trying to find a dhcp address and not getting one for some reason. I have left it for a few minutes and it is now got no display on lcd and flashing blue power button and its trying to find the signal. It has now booted up but I now need to change the transponder type from cable to sat any ideas how I do this?
    Thanks again for all help
    Dec 2011
    I am not sure if it is cable or satellite, I clicked link from Digicon and took this image here http://www.digital-kaos.co.uk/forums...o=file&id=3398 . I am not sure if that is a satellite or cable, can you tell what it is from this information?
    Dec 2011
    To be honest mate, I am just looking for an image that I can use that is recent and has IPTV option as well as uk stuff.
    Dec 2011
    Tried to click on the files mate but getting a error 404 looks like they have been removed. Is there any other more recent ones that you would recommend mate?
  11. #11
    digicon's Avatar
    Jul 2009
    My original Link takes you directly to the Downloads page and not any particular image so that you could browse through the downloads and find the bootloader
    but here it is instead, now just choose an appropriate image
  12. The Following User Says Thank You to digicon For This Useful Post:
    gandalf72 (2nd January, 2016)
