Page 1 of 3 123 LastLast
Results 1 to 15 of 45
    Jan 2016
    Default VVDI vs VVDI2 vs SMOK for VAG
    Hello at first. I am new at this forum. So Hi to all DK Members!!!!!
    I have issue what to buy. I have SuperKey and Miraclone and it does the job but with new Audi and VW it doesn't. I know that the first choice is AVDI but it's to expensive for me. I was reading posts about VVDI and VVDI2 and at this moment I would buy VVDI because it is more stable but I'm afraid that the hardware in it is old and that Xhorse stop making upgrades. If someone have experience with SMOK could You tell me if it does the key for BCM2 ?? What would be Your first pick for VAG for now?? Best Regards.
    Siham's Avatar
    Jul 2014
    VVDI2 or Datasmart 3 .
    Smok never tried.
    No thank , no HELP .
  3. The Following User Says Thank You to Siham For This Useful Post:
    amigokola (10th January, 2016)
    Jan 2016
    Quote Originally Posted by amigokola View Post
    I have issue what to buy. I have SuperKey and Miracle and it does the job but with new Audi and VW it doesn't. I know that the first choice is AVDI but it's to expensive for me. I was reading posts about VVDI and VVDI2 and at this moment I would buy VVDI because it is more stable but I'm afraid that the hardware in it is old and that Xhorse stop making upgrades. If someone have experience with SMOK could You tell me if it does the key for BCM2 ?? What would be Your first pick for VAG for now?? Best Regards.
    VVDI2 reads BCM2 by OBD without a problem ?? I have read post on DK that is not reliable tool.. That Xhorse put it in the market without testing it and that a lot of options doesn't work.
    There are lots of threads on this already its seems someone ask the same question each week.
    Follow this logic the only people that can say which is best are the ones that own all of them... If they own all of them it means that none are brilliant.
    It they dont own all of the tools they can't advise which to get anymore than you can really.
    So having read the threads on each you just have to go with which ever you think.
  6. The Following User Says Thank You to paul_12345 For This Useful Post:
    Jan 2016
    Ok its logical but. There are people who have a lot of stuff and I know that none of it is failure free but I must choose something and I would like to know what is the best for VAG at the moment in keys and ECU swap CS, PIN. Specially AUDI BCM2 and Q7, Touareg. A6,A4,A5,Q3......
  8. #6
    rob h's Avatar
    May 2011
    I own a Original avdi and tango.
    a copy datasmart3+ and vvdi2.
    The vvdi2 is realy good, SV86-B includes vag and bcm2.
    The tagkeytool that is included is not so bad, but not as good as a Original TANGO.
    If you want to do ecu, buy a galletto clone, or ktag. And get a upa or xprog.
  9. The Following 3 Users Say Thank You to rob h For This Useful Post:
    cjawahir (14th January, 2016), instakeys (10th January, 2016), Siham (10th January, 2016)
  10. #7
    Jan 2016
    Someone wrote here that possiblity to f.....ck car up is higher with avdi than vvdi. Is this true ?
  11. #8
    rob h's Avatar
    May 2011
    Avdi does not kill cars, people with avdi kill cars!
    Let get serious: Avdi is one off the best tools for vag, and vvdi is the best avdi clone.
    So that statement does not make any sense.
  12. The Following 2 Users Say Thank You to rob h For This Useful Post:
    Siham (10th January, 2016), yugo45 (10th January, 2016)
  13. #9
    yugo45's Avatar
    SMOK X-Dash can not do BCM-2 keys.
    Only Id-48 keys is possible, means keys with blade like Golf5 or 6 and etc.
    Also you have to buy Key maker + X-dash.
  14. The Following 2 Users Say Thank You to yugo45 For This Useful Post:
    amigokola (10th January, 2016), Siham (10th January, 2016)
  15. #10
    Jan 2016
    Ok. Thank's m8's for help but can U tell me what would U buy for this moment for BCM2,A6,Touareg and VW? VVDI2 or older VVDI with 5th immo ?? It makes me curious why people who have ori AVDI have also VVDI...
  16. #11
    Jan 2016
    Quote Originally Posted by rob h View Post
    I'll get UPA next week. I have Miraclone but I see that Tango is better for VAG. I am turning towards AVDI now but one guy from locksmith industry said to me that is no need for AVDI. That VVDI will do the job and in some cases its better...
  17. #12
    rob h's Avatar
    May 2011
    You dont need tango for vag, Maybe for Crafters keys by dump!
    The med17 and edc17 dumpeditor from vvdi works only if you also own a Condor key cutter.
    And the tango has a good edc med17 editor free build in.
  18. #13
    yugo45's Avatar
    Where do you see EDC17/MED 17 editor in VVDI?
    Only can read CS , Mac and pin form Flash+Eeprom.
  19. The Following 2 Users Say Thank You to yugo45 For This Useful Post:
  20. #14
    rob h's Avatar
    May 2011
    Yes that is right.VVDI For immo on and off and showing CS , Mac and pin form Flash+Eeprom. But only with condor keycutter.
    Quote Originally Posted by yugo45 View Post
  21. The Following 4 Users Say Thank You to rob h For This Useful Post:
    amigokola (10th January, 2016), nedved59 (2nd February, 2016), Siham (10th January, 2016), tekn95 (31st December, 2019)
  22. #15
    Siham's Avatar
    Jul 2014
    amigokola it's time to start pushing thanks button ,members have helped you .
    When someone helped ,saying thank is the minimum.
    Also you have to make your own experience's with tools , yes there is bad or killer tools for some jobs but there is much more BAD USERS ,also if you want to work with any tool doesn't mater where is from you have to make some research and first tool for any jobs is BRAIN.exe !!!!!
  23. The Following 3 Users Say Thank You to Siham For This Useful Post:
    amigokola (10th January, 2016), garagetech (10th January, 2016), yugo45 (14th January, 2016)
