Results 16 to 30 of 45
  1. #16
    Jan 2016
    Quote Originally Posted by Siham View Post
    amigokola it's time to start pushing thanks button ,members have helped you .
    When someone helped ,saying thank is the minimum.
    Also you have to make your own experience's with tools , yes there is bad or killer tools for some jobs but there is much more BAD USERS ,also if you want to work with any tool doesn't mater where is from you have to make some research and first tool for any jobs is BRAIN.exe !!!!!
    Sory Siham I forgot to thanks. Sory to everyone.
    Yes I know that every job needs brain but when I read that with AVDI with Touareg when adding second key U can erase all keys and car wont start... I heard that it is in engine with two ECU. Is this true? I would be very angry if do this with tool for this much $.
  2. #17
    Jan 2016
    Quote Originally Posted by rob h View Post
    I own a Original avdi and tango.
    a copy datasmart3+ and vvdi2.
    The vvdi2 is realy good, SV86-B includes vag and bcm2.
    The tagkeytool that is included is not so bad, but not as good as a Original TANGO.
    If you want to do ecu, buy a galletto clone, or ktag. And get a upa or xprog.
    Rob h why did U buy VVDI2 when U had AVDI ??
  3. #18
    Quote Originally Posted by amigokola View Post
    A lot of people brought VVDI2 when they had AVDI compared with AVDI VVDI is pocket change.
    You will learn every tool will let you down now and again so you always need backups.
  4. #19
    Jan 2016
    Quote Originally Posted by paul_12345 View Post
    You're saying that VVDI2 for backup AVDI when it fails ??
  5. #20
    I'm saying its a backup to try *if* AVDI fails, doesn't say AVDI is bad or that VVDI would work if AVDI failed, its simply cheap enough to have as a backup or if they happen to release something before AVDI.
  6. #21
    rob h's Avatar
    May 2011
    My avdi broke last year. And having it repaired would mean that i have to pay AMS.
    And that is simply wrong! Also,
    My avdi vag package did not include bcm2.
    Now i have vvdi2 with bcm2, for only 1500.
    And it can do Passat comfort module calculation without ECU dump, so vvdi2 is even a littlebit better then avdi.
  7. The Following 2 Users Say Thank You to rob h For This Useful Post:
    amigokola (11th January, 2016), HeXeN (11th January, 2016)
  8. #22
    Jan 2016
    Thank's Rob h. It's answer I was waiting for.
    AVDI can't do key in Passat B6 from comfort module dump?? I can do this with Miraclone and now with VVDI2 when it arrives....
  9. #23
    Apr 2011
    in lebanon
    Hello.
    about AVDI for me is the best tool cause till know nothing damaged in the car when i use it on for any function.but there is a lot of function no present in it same as VVDI.
    1) for example can't adapt keylessgo keys for (golf 6) + can't adapt used steering lock for (golf 6) + can't calculate all kind comfort dump the 7th CS without engine ecu dump, + can't unlock 46 + 48 transponders by dump,but by vvdi can do this all, but vvdi2 is more batter good then vvdi1 cause vvdi don't work (k-line) but vvdi2 can work (k-line) but vvdi2 have some functions can't work but avdi can do it,for 1 example can't calculate odometer for touareg but avdi can do it, so there is another jobs can't do vvdi2 but avdi can.
    2) so here there is no 1 tool can done your job by it you must to have many tools by obd2 + programmers for dump.
    PS:BY avdi can do key by comfort dump for b6 passat, but it is weak in learning system,you can prepare by avdi & learn by VCDS.
  10. The Following 2 Users Say Thank You to haroutioun For This Useful Post:
    Siham (11th January, 2016), yugo45 (11th January, 2016)
  11. #24
    rob h's Avatar
    May 2011
    Avdi requires comfort and ecu dump to calculated.
    Vddi only requires comfort dump.
  12. The Following User Says Thank You to rob h For This Useful Post:
  13. #25
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    Think Avdi will start cloning the vvdi
    and charge you for the privilege
  14. The Following User Says Thank You to whiskeyman For This Useful Post:
    Atex31 (11th January, 2016)
  15. #26
    Apr 2011
    in lebanon
    Quote Originally Posted by whiskeyman View Post
    Hello.
    no bro Avdi always have his own self options.he no need clone from any tools, but if vvdi has more some functions,so this not mean Avdi die, me & all avdi owners hope & must wait for avdi prepare new functions, so Avdi always he is the best now and after.
  16. #27
    Quote Originally Posted by haroutioun View Post
    Hello.
    This from abritus news
    Added support for Megamos 48 keyless-go keys ( e.g. VW Scirroco, Jetta, Golf 6, Tuguan, Touaran 20010+ and others). Free for all owners of AN050
    Also
    Passat B6/CC/B7 decoding of PIN/CS from comfort module dump without using CS from ECU (for some comfort module versions only) ? Get all 7 bytes of CS and PIN from the comfort module dump without having the PIN/CS from ECU. Free for all owners of AN050
    So look like avdi can do keyless and using only.comfort dump for retrieve pin and cs and 7 byte
  17. The Following User Says Thank You to totalkey For This Useful Post:
    amigokola (12th January, 2016)
  18. #28
    rob h's Avatar
    May 2011
    Quote Originally Posted by totalkey View Post
    Also
    Passat B6/CC/B7 decoding of PIN/CS from comfort module dump without using CS from ECU (for some comfort module versions only) – Get all 7 bytes of CS and PIN from the comfort module dump without having the PIN/CS from ECU. Free for all owners of AN050
    Not my avdi.
    I did not aprieciate the AMS.
    So i kept vag23.0 for the last 2 years.
    So good to hear that i did not really miss much!
  19. #29
    Apr 2011
    in lebanon
    Also
    Hello.
    i have all functions in my avdi, but when i write avdi can't do keyless go for golf 6 this mean i tested befor i write here,and about passat not from all dumps can calculate the CS. Some dumps can & some not. 2 years & till now i am ask for this point for vag support, but till now no solution 100%.
  20. The Following 3 Users Say Thank You to haroutioun For This Useful Post:
    amigokola (12th January, 2016), totalkey (12th January, 2016), yugo45 (12th January, 2016)
  21. #30
    Jan 2016
    Hello.
    Sorry to hear that the Company which gets ridiculous amount of money from each device has the customer right up in their ass !!!!!!!!
