Nissan Micra K11 1.0 98'
There is a problem with NATS malfuntion, DTC's are 00E1 00E2. Engine is cranking but doesn't start. CHECK light on the dash is blinking fast.
I've tried many IMMO OFF options in this ECU (also FF method), with units connected and disconnected, without success. It is BOSCH ECU, 93C46. I've attached photos from units. I don't believe that there is no solution for this instead of learning keys (that helped only for a short time) or puting emulator.. It should be possible to turn IMMO off.
