hope this helps...
hope this helps...
Professional BMW immo solutions
Macedonia is one and GREEK!!!
try this also
rumensivanov (5th January, 2021)
Update ! now i get it to work !
i find out the right pinout !
read / write on table is possible
i can post the correct pinout if someon have intrest !
br
I'm Interested also
Hello Folks !
take the two pinout Pic and connect all pins !
on pin 20 you musst put +12V too ! now it should work ! read/write on table !
Hi Doberman
Thanks for the clear pic and excellent diagram for the ECU above.
Have you got a pic of the inside - I am looking to remove the immo on this ECU and been told just remove a certain chip and immo is clear
Or do you have an immo off file.
hi friends
here PIN ok MS6.3
read on table with kess
can you tell me can i read/ write on obd port ? i have correct 38 pin converter !
