The problem lies in the fact that the DPF off using barbells swiftec variable geometry undulates up and down the most in terms of turnover 20000 25000 Annex Ori files and DPF off swiftec if someone could take a look and see if it is good?
Gery (27th April, 2020)
I have this versions damos
Attachment 351009
Encrypt - Decrypt ...
My version of firmware for 1037503277 Original SPRINTER 3.0 CDI V6, EDC17 TC1796 0281016977 , A6429008500 CR6
DPF is switched on.
both files.
Only manual solution work for this. Swiftec or ATR not work good.
If u need assist let me know.
TUNING - DPF Off - EGR Off - ADBLUE/SCR Off - FLAP Off - TVA Off - DTC Off - LAMBDA Off
If I helped you please use button Thanks.
laurenwolf (11th January, 2016)
FULL DPF OFF only manually .
BR
All full worked manual solutions - FAP/DPF OFF, Adblue/SCR OFF, EGR OFF, TVA OFF, SWIRL OFF, O2/Lambda OFF, DTC OFF and etc
Our database available for download 24/7 on EVC server for all legal WinOLS users
atr work perfect
I have read a lot of posts on various forums and only manual editing is correct in this driver no calculators do not count correctly the ECU :![]()
