Its possible to remove the limits...
Hello guys , need a little help with my car. Long story short , trying to make her a little faster. Problem is that even the slightest change(performance) in the ori of the car results in a torque monitoring system error ( DTC P061B) . I've been reading for a while and see here and there that there is a way to disable this torque monitoring system(not so long ago swiftec released and update exactli for this disable module) so i can tweak it as i like. Even paid for a "working solution" 2 times and the result was the same... So i ask if anyone can help out . Here is the ori of the car and some info . Any help will be much appreciated and i will pay for a solution if i have to but this time after i test it(hope u guys understand).
Infineon Tricore TC1796
CPU-ID=0000182000008A02
Internal Flash ID = 0031C002
Internal Flash 2048Kb Protected
OTP Protect: 0x14000 -- 0x17FFF
EXTERNAL FLASH UNKNOW OR NOT PRESENT
EEprom 128Kb Protected
Djunglata_IntFl.rar
DONT FORGET TO LEAVE THANKS + REP!!
DPF, EGR, O2/LAMBDA, ADBLUE, VMAX/SPEEDLIMIT, CHIPTUNING FOR PETROL/GASOLINE AND DIESEL VEHICLES!
EDC17 VAG IMMO OFF, ECU CLONING, BMW EDC17 ECU CLONING!!!
I know it it possible mate .... I asked if anyone is willing to help
That is what the guys i paid said too ... and the files i bought from them did the same thing ! I cant believe it to be a limiter, cause even the slightest change in DW results in this error .
All brand FileService - Custom - remapping company
POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
| Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
2 maps to modify and never need to worry about torque monitoring ever again
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
