Results 1 to 14 of 14
    Nov 2015
    dudley uk
    Default need help mercedes sprinter edc15c6 !!!
    Mercedes sprinter edc15c6 2003
    used a clone galletto v54 to remap, it read it ok,
    I altered the file and wrote it back to the vehicle. now it wont start.
    I think maybe it was the wrong checksum??
    it wont let me read or write it now, error message seedkey,
    when I ID it all that comes up is 5vg
    I have took the ecu off opened it up and desoldered the chip am29f800bt and flashed it with a willem programmer
    hooked it up on the bench but I am still getting the error message seedkey.
    can any one tell me what I have done wrong??? is there anything else that I have to do??
    any ideas would be greatfully appreciated.
    thanks.
    workshop
    send ecu number,find ori flash and writte with willem
    Nov 2015
    dudley uk
    hi mercis,
    I have done this already but still the same.
    75vG.
    0281010921
    1037351776
    CR2/C95
    2.2l
    8FM04B121
    S00C95
    waldi1979's Avatar
    Dec 2010
    Do you have "Start Error" ?
    If YES, read Immo Box HC08 and ECU 5P08.
    Nov 2015
    dudley uk
    it is the old dash, I have on the edc light and the glow plug light.
    waldi1979's Avatar
    Dec 2010
    As far as I remember this text is displayed instead of mileage.
    Nov 2015
    dudley uk
    no the mileage is still shown
    Nov 2015
    dudley uk
    can the ssedkey be located in the original file from the ecu??
    jakkeviet's Avatar
    Apr 2012
    you can use immo emulator cr1 and car work whitout any error
    MOHCIN2's Avatar
    Feb 2013
    IN GOD'S EARTH
    you can also try another ecu just swap eeprom or right your original file from your backup with boot mode maybe with obd your tool isnt enough good
    jakkeviet's Avatar
    Apr 2012
    problen is not ecu. clone galletto can derstroy eeprom that is reason why car no start
    Top Poster antonnio_stef's Avatar
    romania
    who need a full flash and eeprom autosync this tipe of ecu .. 02810109210cr2.35 2.2.L A 000 153 61 79 is free to use..
    u can use this files in any ecu for sprinter 2.2 chasis 904
    & - sau WWW.DIAGNOZASECTOR5.RO
  13. The Following 7 Users Say Thank You to antonnio_stef For This Useful Post:
    1971 (17th February, 2019), eLKa (25th April, 2019), Makson4eg (17th January, 2019), p1gl3t (23rd May, 2019), ruwi (20th August, 2021), taxi300 (7th May, 2020), Tyson500 (7th February, 2019)
  14. #13
    May 2016
    Antonio! Muches Gracia's you real Help Me!!!! Flash file is stock?
  15. #14
    May 2016
    Just check 100% stock
