Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    Default NCDC 2013 and CDC3 pairing - Pin from CID also
    Hello guys,
    Can someone tell me the procedure of pairing the NCDC 2013 and CDC3 lower half of the radio?
    On the display is CDC safe.
    CID and NCDC 2013 are paired.
    I am attaching the display dump so I can extract pin from it.
    Also can anyone provide photo near 24C64 of CDC3?I have one SMD missing.
    Swapping board from old to new CDC3 won't work,because eeprom on old board is rotten - water damage.
    Here are 24C64 and 93C56 attached.
    Regards,
    Sima
    Feb 2010
    WALES
    Quote Originally Posted by simaservis1108 View Post
    Hello guys,
    Regards,
    Sima
    Pin from CDC3 is 2131
    wbr
    Nov 2013
    Lietuva
    CDC dump in delivery state CDC_24420619_NCDC2015_VIRGIN.rar
    you need op-com or tech2 :
    1.disable theft protection for ncdc+cid with ori pin code extracted from cid
    2. write my CDC dump to eeprom
    3. enable theft protection for ncdc+cid+cdc with your pin code
    OPEL / SAAB EDC15M * PSG16 * EDC16 * EDC17 * DENSO * ACDELCO cloning / programming / resetting
  4. The Following 7 Users Say Thank You to bajad For This Useful Post:
    dunnnia (28th February, 2017), KierAn20 (14th January, 2016), Raimax (14th January, 2016), REZON (14th January, 2016), shooting (14th January, 2016), simaservis1108 (14th January, 2016), VLmaxTXD (19th May, 2018)
    Nov 2013
    Lietuva
    pin from CID - 1868
  6. #5
    Aug 2013
    Serbia,Belgrade
    Code not correct,security times goes up,and CID/GID deactivation failed.
    Also CDC deactivation failed.
  7. #6
    KierAn20's Avatar
    Sep 2009
    UK
    Does Tech2 find the CDC status as "Delivery state"? Or "Id not ok"?
  8. #7
    Aug 2013
    Serbia,Belgrade
    CDC with new dump - delivery state.
  9. #8
    KierAn20's Avatar
    Sep 2009
    UK
    I never yet found the code hard stored in any of these pre-2005 CID (or GID) displays. I know only one person who cracked the codes and pairing data on these and he seems to think code is hard stored in flash on NCDC EHU and only pairing data in display. Whether this is 100% correct.....................
  10. #9
    Aug 2013
    Serbia,Belgrade
    Yes,in flash code location I know for NCDR 1100,not for this one,unfortunately.
  11. #10
    Aug 2013
    Serbia,Belgrade
    Can we somehow change pairing code in CDC3?
  12. #11
    Nov 2013
    Lietuva
    sorry , pin calculate program
    File Name: M93C56.bin
    Unit: Astra MK4 - CID
    EEPROM: 93C56 EEPROM
    Vehicle: Astra G
    Security Code:1868
    P.S. then you do disabling theft protection CDC must be disconected electrically and in CAN configuration of NCDC2013 CDC should be set to OFF .
  13. #12
    Mar 2022
    Hello everyone .. I bought the CDC3 TB to work with NCDR1100 and CID on an opel vectra b .. I found the plug in the glove compartment, I connected it, I have ncdr1100 with CID from the factory..the system saw it, it started to play a CD of it, and after 10 seconds it cuts off the sound. the CDC menu disappears and I see only check disk 2 or check disk 3 and it stays that way, it doesn't do anything anymore ... and the CDC button only does nothing.
    If I change the songs quickly, play one after the other but don't leave it for more than a few seconds ... then it locks the system and it stays on check disk 1 or 3 or 2 again.
    Opcom live data says “id not ok”
    And for some reason I can't find the car's pin anymore.. so i don’t have PIN for CID and NCDR which i know they are the same PIN..
    Please HELP
  14. #13
    Mar 2022
    Thank you for no help ..
  15. #14
    Jan 2016
    hi, I replaced the ncdc 2013 radio with the same one, the cid display remained original, now I have “display safe”, can someone tell me how to link the radio to the display?
  16. #15
    Feb 2010
    WALES
    Quote Originally Posted by geka1111 View Post
    Update using this dump then pair using 2987
    wbr
  17. The Following 3 Users Say Thank You to shooting For This Useful Post:
    cheero (19th October, 2023), diaz38 (12th October, 2023), geka1111 (12th October, 2023)
