Dalautos (6th February, 2019)
i am sure if you if you got avdi can be repaired this is common with fvdi better buy peugeot obd reader as it is safe to read pin next time any other members they will be more knowledgeable than me .
FVDI kills PSA BSI units if pin reading is attempted , never try and read a johnson controls unit with it , buy codes instead . ive not got fvdi as have avdi which is good on these , the last one i saw on another forum ended up having to go to dealer , but im sure someone here will be able to help repair.
Looks like eeprom is crached, anybody have virgin for this BSI?
966405878002
BSI04EV K01-00 031109
V05.01
BOOT 28120836-4
HARD 28119246-2C
Check here and maybe solution for your problem:
http://blog.obd2express.co.uk/2015/0...illed-by-fvdi/
be very lucky if this works
usal fvdi it amazes me as many member use this tool when they know is very bad for destroying cars .
Eeprom corrupted, flash is ok. What adapter besides lexia can work with pp2000 to adapt virgin Bsi?
Flash is dead for 100% if you tried to read with fvdi, you can repair it buy write flash from second hand bsi with same hw and sw.
If It Helped Push Thanks
We have backup copy in AVDI folder of flash. How to check if flash dead?
BSI reply to diagnistic commands via FVDI, give its number and many other info.
Does the vehicle response to switch on, light , hazard, locking ?
No, not work
sbtriny (1st April, 2016)
So the flash is dead, you need reflash it with FVDI or AVDI or other tool you have you need same part number and your problem will be solved,
bearheroes (18th January, 2016)
But eeprom corrupted too, i see only one VIN, in other original dumps must be 3 VIN.
Frriend, if you want to repair the bsi you need to reflash the bsi , leave the eeprom for now its not your problem.
