Page 14 of 18 FirstFirst ... 49101112131415161718 LastLast
Results 196 to 210 of 260
  1. #196
    Fec001's Avatar
    Hi!
    Please switch off immo 100% soluiton.
    Clio 2001 1.2 8v
    S110138000 B
    8200059086
    8200044437
    Thanks!!!
  2. #197
    Louislesinge's Avatar
    Jun 2017
    French Jungle
    Then there is solution .
    No good solution...
    Greetings
  3. #198
    Fec001's Avatar
    I think mark1, there is no can chip in ecu.....
    I have only ECU here
  4. #199
    Shmortz's Avatar
    in the middle of nowhere
    here you are m8, cut pin58
  5. The Following User Says Thank You to Shmortz For This Useful Post:
    Fec001 (26th February, 2020)
  6. #200
    Jun 2017
    French Jungle
    So here you got it :
    Greetings,
  7. The Following User Says Thank You to Louislesinge For This Useful Post:
    Fec001 (28th February, 2020)
  8. #201
    Oct 2019
    Ukraine
    Hi!
    Siemens Sirius 32n
    S110130338 A
    8200107212
    8200044437
    AM29F200BB.rar
    Thanks!!!
  9. #202
    Jun 2017
    French Jungle
    There is the off.
    Greetings,
  10. The Following User Says Thank You to Louislesinge For This Useful Post:
    rafal (25th March, 2020)
  11. #203
    Nov 2015
    Hy everyone, can you help me with Immo OFF for Twingo Sirius 32N
    S110138000 C
    8200059086
    8200044437
    File read with K-Tag
    Thank you!
  12. #204
    autocargo's Avatar
    Your file off. Cut pin 58.
  13. The Following User Says Thank You to autocargo For This Useful Post:
    stefyhgs (7th April, 2020)
  14. #205
    Jun 2017
    French Jungle
    Another solution:
    Greetings,
  15. The Following User Says Thank You to Louislesinge For This Useful Post:
  16. #206
    Nov 2015
    Thank you! I used autocargo's file, but there are both very similar, so I am convinced that both work!
  17. The Following 2 Users Say Thank You to stefyhgs For This Useful Post:
    autocargo (8th April, 2020), Louislesinge (8th April, 2020)
  18. #207
    alfons37's Avatar
    Need help with immo off, i have working immo off but think is corrupted, anyone have same orginal file with immo off?
    Renault clio II 2001
    Siemens sirius 32n
    s110138000B
    8200059086
    1.4 16V with AC
    No can chip in ecu
    And need check so file is not corrupt, car not start with this file maybe bad checksum
  19. #208
    Jun 2017
    French Jungle
    There are your own file off done (it seems to be Chk OK) and another from my data.
    Did you cut 58 line?
    Greetings,
  20. The Following User Says Thank You to Louislesinge For This Useful Post:
    alfons37 (9th April, 2020)
  21. #209
    alfons37's Avatar
    I try your file and work but car go 5 min and car die and engine light go off on dashboard. I have try replace am29f200bb an solder good, solder 12 times I think ecu is bricked
  22. #210
    https://t.me/pump_upp
    [QUOTE=Fec001;3805840]Hi!
    Clio 2001 1.2 8v
    S110138000 B
    8200059086
    8200044437
    More specs needed does the car as a/c?
    Here cut pin 58 pass cascais1
  23. The Following User Says Thank You to cascais For This Useful Post:
