Results 1 to 5 of 5
    Default M8 quad core box genesis problem
    Hi, I have an M8 box running Kodi, if i click on a live tv stream it will play pretty much straight away, but if i search in genesis for a box set, the links will show up but will not open, and the no stream available message will appear(whatever i search for) I have uninstalled and installed Genesis again but to no effect, IStream will not even show the links for any box sets. I have a working box downstairs ran by 1GB homeplugs, the non working one upstairs is connected straight from the wireless router connected to the modem and running using ethernet connection. any help would be appreciated. thanks
    Jul 2011
    Hi genesis is pretty much finished, you need to use salts or velocity
  3. The Following User Says Thank You to dp11 For This Useful Post:
    parley (22nd January, 2016)
    Hi thanks for your reply, I have tried both of them, all seems good, I do a search, links are retrieved, then when I try to open a link or choose auto play, it will either fail or the spinning"working" will appear bottom right of screen then nothing happens. Any ideas?
    Jul 2011
    Not sure, maybe try a VPN see if your ISP is blocking anything. I have just started using real debrid with salts and its working quite good.
  6. The Following User Says Thank You to dp11 For This Useful Post:
    Apr 2011
    Phoenix, hd online movies, velocity, origin, pub films & even showbox all good sources for films etc. Hope this helps.
  8. The Following User Says Thank You to joshua99 For This Useful Post:
