Maybe this can help you!
Whats the best way to open these Opel/vauxhall ecu's? they have a white plastic base that looks to be bonded or molded to the unit?
cnd (23rd January, 2016)
Open ECU and make a picture,there is two PCB models!
mcmcmc (23rd January, 2016)
Connection to PCB!MAC7242 processor.
Dosnt module 13582437 AS2437EM050A1464 Astra J SDM10+ have XC2361A-56F ?
chiorbeq (24th January, 2016)
I find only MAC 7242 inside!
You are upload picture for SDM10 what is Autoliv module and have MAC7242 and this module is SDM10+ what is module with XC2361A. Type of module write on pcb board and on module outside
The picture is from a MAC inside and is from SMOK JTAG Programmer!I read and write 3-4 ECUs only with MAC processors.if you find this ECUs type with XC infineon is a good news!Smok don't have a XC connection for this ECU type.
Yes, that is okay. But in Opel exist airbag modules with MAC and with Infineon.
Module 13582437 Astra J is module with Infineon.
Modules 13505823 AB, 13574896 AF, 13575683,13576859 AB, 13577275 are with MAC7242.
And member mcmcmc is ask pinout for module 13582437.
Modules: 13589374 AB, 13589405 AV, 13589413 MB, 13590216 DK,13582437 are with Infineon.
Check this posts:
http://www.digital-kaos.co.uk/forums...light=13582437
Maybe exist 2 different modules with same number. I do not know.
13582437 module have INFINEON chip inside, not MAC
A picture with connection on PCB for this ECU?
Any info on connection for this ECU vauxhall 13589689? think it is infineon XC2361A-56F
Clear DTC with suitable tester !
i need help with Astra J 2011.
Original Airbag module is missing and have another but when i have fault code B1001-00. With OP-COM 2015 menu for programming is disabled. Tried BSM but there is nothing that i can program (nothing happened when input security code)
