Does anyone have an original file for this EDC17CP11 TDV8 SW 508545..
This is the same wire up as the TDV6 for anyone that needs to know..
Cheers
Nik
Can anyone tell me is reading and writing of these 4.4 ECU's in boot mode the same wire up as the EDC17CP11 that is used in the 3.0 Ford / Jag's etc.. Don't know much about this car, I have just been given the ECU.. Someone has been in this before and done a DPF Delete but is running bad so customer wants putting back to standard..
Cheers
Nik
Cheers
Nik
just a quick bump...
here you have original
Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
POPS & BANGS (Schubabschaltung, Crackles) on allmost every petrol
Music73 (30th January, 2016)
Excellent... thank you..
Sent from my SM-T533 using Tapatalk
i guess this is the Int Fls..
Here is the Files read from this ecu.. Just comparing the version posted by Andrei2015 and there is a few differences and not just within the maps..
RANGE ROVER EDC17CP11 BAD DPF DELETE_ExtFl & IntFl.rar
Cheers
Nik
