you cant just new,i doing that on my shop try couple time
but didnt work.
br
but didnt work.
br
Col19 (11th December, 2019)
Thanks mate, I got to keep trying, save ???
PCF7946
See bottom of page
Replace chip, cards are very hard to take apart
Peter
yes but from where get for UHC block pin code?
With this software you don't need pin code
www.Abritus72.com VAG Commander BMW Commnader HITAG-2 key programmer
Peter
The ICC Immo Code Calculator can do the trick , but it`s very expensive ~ 500 euro for the basic package and the Renault stuff. After you get the pin i think a Clip or DDT will do the trick.
Am I correct in thinking then you replace pcf7946 in card, with something like this:
1 pcs IC Chip PCF7946AT PCF7946 Key Transponder Chip: eBay Motors (item 260614026401 end time Sep-01-10 11:48:20 PDT)
then you can reprogram into another car .
or is there more to it ?
has anyone had success with this?
You need every tool in the book, to do this auto locksmith job.
yes you are correct obd master. replace 7946 and the chip must be in cipher mode and code into any of the renaults after that. done a few already.
Bit of a thread bumper this, if i got a zed bull clone using transponder production id46 would this put pcf7946 chip in cipher mode, or could a zed bull clone put chips in cipher mode.
much thanks as always.
at the moment zed-bull can only unlock id48 ,,vag chips
they have added id46 cloning now but unlocking 46 is not available yet...
m8 i dont want to clone one of these:
10 pcs IC Chip PCF7946AT PCF7946 Key Transponder Chip: eBay Motors (item 250644475194 end time Sep-01-10 11:48:50 PDT)
just prepare for programming on vehicle, when soldered onto card.
