aerokbzas (12th June, 2018)
Hello to all 1
Need to remove speed limit (or set to 130km/h) on Fiat Ducato EDC15C7.
Here is 29F400 from 0281011048 1037370662.
Thanks in advance !
'" live and learn........ if you wont ....you ain't "
_______ . ____ . __ . __ . _______ . __ __ __ ... ---
If my post was HELPFUL please push THANKS button
Vmax off
no pass
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
There are 4 speed limit blocks now all are 300km, 100% works
teamtuner (2nd February, 2016)
Hi To all members!
I need to remove speed limiter from Fiat Ducato 2.0 jtd 2004
ECU EDC15C7 0281010346 HW:9646138580 SW:1037351989
Flash 29F400
Thanks!
now is 130km
here is eeprom
georgedigital (2nd April, 2020)
my friend with your file car dont start.I have immo problem
any other solution?
georgedigital
no immo problem,problem chk to flash modi,repaired chaksum and car start ok............
I cant make chk...Read and Write with galletto 1260.Did you know how can i do?
well for starters chuck that galletto 1260 in the bin and get a better tool
TUNING--FILE SERVICE--VMAX--EGR--DPF--FLAPS--LAMBDA--DTC--IMMO..........POSSIBILITIES ARE ENDLESS
SPECIALISE IN TUNING DIESEL ENGINES
(DEMON DEVELOPMENT)
IF I HELPED YOU DONT FORGET TO HIT THANKS AND REP POSSIBILITIES ARE ENDLESS
