Results 1 to 7 of 7
    Default B245 Key Generate
    Hi guys
    Can someone please calculate and generate the keys of this EIS module cause my SKC calculator wont generate and the other that I ordered hasn't arrived yet
    Please I need it urgent at last one cause I need to finish the job
    Here is the dump file
    vanos batam's Avatar
    Batam-Indonesia
    Quote Originally Posted by 3R1 View Post
    Hi guys
    heloo try this
  3. The Following User Says Thank You to vanos batam For This Useful Post:
    3R1 (6th February, 2016)
    Thanks vanos. Will try and report
    Just tried and it didn't work
    The red light remains on when I insert the key in ignition but it dosen't release the steering lock and it dosen't turn the ignition switch
    Batam-Indonesia
    Steering lock is faulty
    Maybe ..
    What the problem before?
    Proton-Neutron
    not work becaus dump key from vanos batam pass is zero 00 00 00 ...
    Finally it generated and key working like a charm
    Will compare both files vamons and see what is the differnce betwen them.
    I just wanted to add a spare key .
    I use SKC calculator and everytime that I get key generated from it works perfect.
